Enamel paint on vinyl tracks?
Posted by ipms40049 on Wednesday, November 21, 2007 2:37 AM
can you use enamel on vinyl tracks?
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
    October 2005
Posted by usmc1371 on Wednesday, November 21, 2007 7:07 AM
Sure can.  I believe enamel works better than acrylic for most flexible vinyl tracks.  The enamel paint is more "flexible" than acrylic which can crack and flake off if the track is bent.
Jesse
    August 2005
Posted by Phil_H on Wednesday, November 21, 2007 7:49 AM
It depends on the track. For example, the older Tamiya type that had to be joined using a hot screwdriver are pretty bulletproof. However, I recall reading accounts of the newer "gluable" type disintegrating after being washed with enamels.
You will find lots of information by putting the following term into the search box at the bottom of the page:
painting vinyl tracks
and for info about disintegrating tracks, see this thread: /forums/110946/ShowPost.aspx
    October 2005
Posted by usmc1371 on Wednesday, November 21, 2007 9:42 AM
I'd image that disintegrating is due to the heavy amount of thinner used in the wash not the enamel paint itself.
Jesse
    October 2005
Jesse
EDIT: How did that double post happen? Weird...
