Tempera troubles and Future covering questions
    June 2007
Posted by Col_Shaggy on Tuesday, December 4, 2007 11:32 AM
I just finished a model and I figured I would try a Tempera wash to bring out the panel lines. It worked fine on the top side of my plane, where it had a camo scheme, but on the bottom, where it was gray throughout, it left pale black marks along the borders of the lines that wouldn't wipe away. I had used Model Master 2936 High Gloss clear coat, from the spray can, to cover my paintjob prior to decaling and another coat to seal the decals afterward. Then I laid down the Tempera over that coat, let it dry, and wiped it away. The same process was used for top and bottom, with the exception of the clear coats which were applied to both sides before the next step, and between the spraying of the last gloss coat and applying the Tempera I allowed about 24 hours for the clear coat dry. Did I rush the Tempera stage?
I'm also thinking about trying out Future on my next project, will I have to drop the Tempera for panel highlights?
There are no masterpieces. Everything is training. - Me
    January 2003
Posted by Triarius on Tuesday, December 4, 2007 3:03 PM
Did you rush the tempura? In a word, maybe…
All coatings, clear included, tend to be drawn into corners of any kind, leaving a thicker layer in and near those areas. This is a result of surface tension, and there is no way to prevent it.
As a result, the coating in and near panel lines is thicker than elsewhere. It takes longer to dry and longer to cure. What often happens is that after the surface is dried and cured, the coating below the surface still contains small amounts of solvent. This solvent migrates away from the panel line (where the coating is thickest) to the thinner areas at some distance from the panel edge. Where the solvent finally migrates out of the coating, the coating is softer and uncured for nearly as long as the heavier coating at the panel line. It can take up to twice as long for such areas to dry and cure compared to the middle of the panel. Applying your wash to this slightly sticky or possibly faintly rougher surface resulted in pigment being trapped there.
It sounds from your description that this is what has happened. This is a common problem in all paint applications, not just scale modeling, and it is worst when a heavy coat is applied, instead of multiple light coats.
You may be able to remove the stains by polishing the surface with 2000 or finer grit.
    June 2007
Posted by Col_Shaggy on Tuesday, December 4, 2007 7:11 PM
Thanks for the reply.
Next time around I will give the clear coat longer to dry, but should I also give each coat time to dry?
for instance:
clear coat > dry time > decals > clear coat > dry time > Tempura
Posted by MikeV on Tuesday, December 4, 2007 8:48 PM
for instance:
I say clear coat, 24-48 hours, decals, 24 hours, clear coat, 24-48 hours, Tempura
    January 2003
Posted by Triarius on Tuesday, December 4, 2007 9:32 PM
Essentially Sign - Ditto [#ditto] Mike's post, with the caveat that high relative humidity and low temperatures extend both drying and curing times. If, for example, I was in St. Louis in July, without air conditioning, I'd wait more than 48 hours at ambient. Florida would be similar.
Drying and curing can be shortened by gentle warming, such as in a food dehydrator or similar apparatus.
Posted by MikeV on Tuesday, December 4, 2007 10:17 PM
With my drying booth I can gloss coat with Future and be ready to decal in an hour.
Then I decal, let it sit overnight and then gloss coat again with Future, one hour later I apply the wash, then another hour and I spray the clear flat. Thumbs Up [tup]
    August 2007
Posted by some assembly required on Tuesday, December 4, 2007 10:40 PM
mike v could you please explain your drying booth? how could i best make one? thanks in advance
Posted by MikeV on Wednesday, December 5, 2007 12:18 AM
Just find an appropriate sized cardboard box and line it with aluminum foil.
Cut a small hole in the top and attach a light socket into it through the top and screw a 100 watt bulb from the inside to sandwich it in place.
I put the model in there and turn on the light and put a towel or old T-shirt across the front to keep the heat in. I have a thermometer in it and it gets to about 110-115 degrees inside the box. About an hour in there and it's dry.
Here is mine:
    October 2003
Posted by ModelNerd on Wednesday, December 5, 2007 2:21 AM
 Col_Shaggy wrote:
... it left pale black marks along the borders of the lines that wouldn't wipe away....
 The only time I had trouble removing tempera from a model was the first time when I did not glosscoat it prior. But I see that you did that, so the problem you describe should have not happened (!) Can you post a pic?
- Mark
    September 2003
Posted by Daywalker on Wednesday, December 5, 2007 8:56 AM
Mike,
Thanks for sharing the info and photo of your drying booth!  Looks much more effective than mine, think I am gonna make a new one.  Thanks my friend!
Frank
Posted by MikeV on Wednesday, December 5, 2007 10:47 AM
My pleasure Frank.
I actually got that idea from Greg (Plasticmod992).
I would like to put a fan in it also but am afraid it would cool it too much unless I can find a real small one that turns low RPMs.
    June 2007
Posted by Col_Shaggy on Wednesday, December 5, 2007 11:13 AM
I can't really post a pics, can't find my camera, but what was said before I think is right. I just rushed it. Everything I'm working on now are kitbashes of fighters I designed for a book I'm writing and serve more for reference than display pieces, so I don't mind experimenting and learning new techniques on them.
    January 2003
Posted by Triarius on Wednesday, December 5, 2007 12:05 PM
 MikeV wrote:
My pleasure Frank.
Mike, you can find small ones sometimes in gardening supply places. They are used for air circulation over sprouting plants. This is also a perfect place for a small muffin fan.
I personally would never put a 100 W bulb in contact with cardboard. What I would do if I didn't have a food dehydrator would be to stand the bulb in the box opening with a small fan blowing past it.
Posted by MikeV on Wednesday, December 5, 2007 12:28 PM
Ross,
I thought of something like a computer fan only 120v but they blow fairly hard.
What is wrong with a 100W bulb near the cardboard?
That bulb doesn't produce near enough heat to reach the flashpoint of cardboard which is roughly 451 degrees for paper.
    August 2007
Posted by some assembly required on Wednesday, December 5, 2007 6:21 PM
thanks for the pics mike , im definately gonna make me one.
    January 2003
Posted by Triarius on Wednesday, December 5, 2007 9:50 PM
Mike,
It's not the amount of heat that a 100W bulb produces—its surface temperature may be below the ignition threshold of cardboard. But cardboard is a remarkably good insulator—it transmits heat that it absorbs very slowly. So when you place it close to a good source of heat, it keeps getting hotter until a state of equilibrium is reached or it ignites.
The foil certainly helps, as it is an excellent conductor and reasonable reflector. Nevertheless, it is quite thin—I'd still put the bulb on the bottom.
Go ahead, call me paranoid. Accidents are things that should not happen, but do.
    May 2005
Posted by Bgrigg on Wednesday, December 5, 2007 10:41 PM
The voices in my head tell me that you aren't being paranoid.
However, I have above my head is a CE, UL and ESA approved lighting fixture that uses a sheet of cardboard with a foiled side to seal the bulbs from the electrics. The bulbs come within 0.25" of the cardboard. It is designed for incandescent bulbs, and is an glass enclosed fixture designed for bedroom ceilings. It holds three bulbs rated for no more than 75 watts (225 total). If this is considered safe for use in residential bedrooms, Mike's drying rig should be fine.
I don't use a drying cabinet of any sort, as I work on many different projects simultaneously. I have a build table for gluing. A paint table for brush painting and detail work, and my spray booth. I just leave whatever I've painted in the booth for 24 or more hours. it has doors on it, and it almost completely dust free.
So long folks!
    January 2003
Posted by Triarius on Thursday, December 6, 2007 12:54 PM
Bill, I'd be willing to bet that the cardboard in those fixtures has been treated with a fire-retardant chemical.
If I were to do it the way that Mike describes, I would unfold the box, lay it flat, and saturate the cardboard with a saturated solution of baking soda, a.k.a. sodium bicarbonate. After it was dry, I would then reassemble it for use. When sufficiently heated, bicarb breaks down and releases carbon dioxide. Won't make it fireproof, but will improve its fire resistance.
I wonder if the voices in your head are the same ones as in mine? Maybe we're on a party line? Mischief [:-,]
Posted by MikeV on Thursday, December 6, 2007 3:13 PM
How about I just line it with Nomex? Laugh [(-D]
    January 2003
Posted by Triarius on Thursday, December 6, 2007 4:40 PM
I was thinking: asbestos…… Evil [}:)]Laugh [(-D]
Posted by MikeV on Thursday, December 6, 2007 4:47 PM
In CA? They would put me in San Quentin for life! Laugh [(-D]
    January 2003
Posted by Triarius on Thursday, December 6, 2007 8:02 PM
Back when I was in college, there was a joke about a sign on highways leading out of CA: "You are now leaving the State of California. Please resume normal behavior."
Now, we know what the obverse of those signs say: "You are now entering the State of California. Everything is known to be hazardous to your health."
