Hmmmmmm, I use MM Clear Flat too and haven't had any problems, even though I generally brush paint it on, but - it's almost always going down over MM enamels, so you have an enamel going on top of an enamel, which greatly reduces your chances of one of the 9 bazillion acrylic/enamel reactions we all live in fear of.
If you don't want to use Future as a barrier coat between the Tamiya acrylics and the MM Flat, and you use an airbrush, then look into the Tamiya Flatener (X-20? I think). Just remember that it is an additive, and has to be mixed with one of the Tamiya clear coats to give you a flat finish.
