Daywalker - thanks for the tip, i've noticed it seems to take a while to dry, didn't realise it would take that long.
Just to follow up on this link:
I experimented last night spraying the Clear Gloss with a much lower ratio 4:1, and lower air pressure, 10 psi.
I found that the Gunze Sangyo clear gloss is way to thick at this ratio, and it sprayed on horribly - not at all smooth and even. I think i'll go back to thinning it around 60:40, and then vary the air pressure. Given glosses need be thinned more than matts, i can only assume this is true for the clear gloss.
Also, i've been experimenting with Pledge One Go (similar to Future), i seem to have better results with this. It does require a little bit if practice though, as it is much much thinner than the paint - it does pool or run if the air pressure is too high.
My only concern is the Pledge has a yellow tinge to it (in large volumes), you can't notice it in a small jar, but certainly it looks yellow in it's bottle. I hope it doesn't interfere with light colours.
cml
