24" Peace Keeper Mini spray booth
    October 2007
Posted by DD-557 on Saturday, January 19, 2008 9:38 AM
I live a cold climate and normally do any spray painting, gravity feed AB & rattle can, after winter is past opening the shop windows and running a fan(s) to exhaust the paint residue. I now want the capability to spray during the winter months and think a small spray booth exhausting through a panel trapped between a sliding window and window frame would be in order.
My primary projects will be WWII USN ships in 1/16" scale and my first build will have a hull length of 19”. I see that Pace Enterprises has a model called the 24" Peace Keeper Mini that is semi open ended and I’m wondering if it would be adequate for the job. The open ends may not draw as good as a close ended booth but it would allow moving a longer piece, such as a hull, along so that the area your painting would be in the center of the booth. Not prefect but would at least allow me to exhaust fumes without the lose of to much heat from the shop
You can see the 24" Peace Keeper Mini at http://www.pacepaintbooths.com/pace/
Thanks for your time.
    October 2007
Posted by DD-557 on Saturday, January 19, 2008 3:07 PM
Since posting the above message I ran across MikeV's thread on the Badger Spray Booth and think that because of what I will be painting in front of the booth it will serve me better than the Peace Keeper Mini. I really like the open visibility and the ease with which one can setup lights for the project being sprayed. So, thanks to everyone who stopped by and thanks to MikeV for his evaluation thread on the Badger Spray Booth.
Patrick
