Let's see your compressor
Posted by MikeV on Saturday, January 26, 2008 9:19 PM
Since we had a thread asking to show our airbrushes I thought I would post one to show our compressors.
Here is mine. It's a Badger Million Air oil lubed compressor that I wired a 120mm 54 CFM fan to it's switch so that it runs all the time the compressor is plugged in.
    May 2005
Posted by Bgrigg on Saturday, January 26, 2008 9:29 PM
I don't have a pic of my compressor but mine looks much like this one. Slightly different shroud and it's labelled "Husky". Works well, though it's pretty loud. I keep mine outside in a well ventilated box and run a hose inside my house to spray with.
I'm trying to save up for a silent in house compressor, but there are so many kits out there!
So long folks!
Posted by Wingman_kz on Sunday, January 27, 2008 7:30 AM
Don't have any pictures handy but I use an Iwata Sprint Jet piped to a 2 or 2.5 gallon tank from an old Cambell Hausfeld compressor. Tank serves as a large moisture trap and eliminates any pulsing. Also there's no bleed valve to hiss. That was louder than the compressor. I use the regulator that was on the tank and a second moisture trap.
Tony
    August 2007
Posted by ben1227 on Sunday, January 27, 2008 1:33 PM
Nothing special, but along with a regulator it works just fine for me, except that it heats up so hot you can't touch it after about 30 minutes of use.
.:On the Bench:. Tamiya 1/72 M6A1-K
    December 2007
Central Pneumatic air compressor
Posted by JViguers on Sunday, January 27, 2008 2:07 PM
I have it for almost 6 years and it still runs good. Big Smile [:D]
On the workbench: Pegaso 90mm Templar Sergeant
    August 2006
Posted by HawkeyeHobbies on Sunday, January 27, 2008 2:38 PM
It meets my needs...I added a regulator and moisture trap.
Gerald "Hawkeye" Voigt
    January 2007
Posted by Gigatron on Monday, January 28, 2008 8:43 AM
Here's mine, 3 gallon tank, built in regulator.  I have a pistol grip water trap at the brush end.
-Fred
    September 2003
Posted by Daywalker on Monday, January 28, 2008 9:41 AM
This is what I use, Airbrush City's twin cylinder with 1 gallon tank, very quiet at 59db!  I've had it for one year and I love it! Big Smile [:D]
Frank
Posted by MikeV on Monday, January 28, 2008 9:49 AM
Mine is about 40 dB. Tongue [:P]
    January 2007
Posted by Gigatron on Monday, January 28, 2008 10:41 AM
Once my tank is filled (under a minute), mine is 0 dB for over 2 weeks.  Beautiful thing about a 3 gallon tank, the infrequent refills Big Smile [:D]
-Fred
Posted by MikeV on Monday, January 28, 2008 12:13 PM
-Fred
2 weeks? You leave air in the tank for 2 weeks? Bad idea my friend, drain that tank every day or it will rust on you from the inside out.
    September 2003
Posted by Daywalker on Monday, January 28, 2008 3:33 PM
Sign - Ditto [#ditto]
Frank
    October 2006
Posted by Inquisitor on Monday, February 4, 2008 5:39 PM
I started with this:
Which I loved, then graduated to this (which I bought sec hand...):
Which has a larger tank.
p.s. why the fan on your millionaire?  Decrease heat buildup?  If so, perhaps you should get a bigger compressor, so it doesn't have to work so hard.
Posted by MikeV on Monday, February 4, 2008 5:57 PM
I have a fan on it because all compressors benefit from a cooling fan as heat is what kills a compressor. The cooler you keep it the longer it will last.
That Super Silent you had was plenty enough compressor for modeling.
I believe that is the same exact motor and insides as my Badger as most all are made in Italy.
Why the bigger one? What brand is that blue one anyhow?
    December 2007
Posted by GluingCheese on Monday, February 4, 2008 6:47 PM
I have a little one gallon that works great.  Under desk, fairly quiet, but does not have a moisture trap.
Occasionally, my gun will "spit" extra paint.  Could this be the problem?
And a hot tip, don't need to follow it if you want to live life on the edge, but always turn the compressor off before calling it a night.  Nothing like having that little motor automatically fire up about 10 minutes after you crash. (No hobby room.  Bedroom is the computer/hobby/sleeping quarters).
    May 2005
Posted by Bgrigg on Monday, February 4, 2008 8:11 PM
Yes!
So long folks!
    December 2007
Posted by GluingCheese on Tuesday, February 5, 2008 5:37 PM
Why thank you.
 Now I have something more to do.
 (Stoked that is the answer.  Sounds like the problem will be easily solved.  Thank you thank you thank you.)
    May 2004
Posted by cbaltrin on Thursday, February 7, 2008 11:05 AM
See it? bottom left of frame... ;-)
On the Bench: Too Much
