I'm thinking of trying Talon's Acrylic NMF - Bronze instead of Floquil's - Brass for the propellers on a DE that I'm getting ready to start. Although brass is called for I'm thinking that bronze may be a better choice?
The props are cast pewter and the plan is to prime them with lacquer-based automotive primer-surfacer in a spray can for the undercoating; I assume there will not be a compatibility problem between the lacquer and the Talon acrylic.
Since I will be spraying the Talon with an AB what do I use to thin the paint with and what may the ratio be?
Thanks.
