Missing badger 150 part or not?
    February 2008
Posted by Dementiak on Monday, February 11, 2008 2:17 AM
Hey guys I'm new to this very informative forum.
I just bought myself my first airbrush. the badger 150.
Ok so i tried it out and it wouldn't work... So i decided to dismantle it. thinking that maybe the needle was stuck coz of shipping or something. as i was looking at the manual making sure that notihing was missing. i noticed i couldn't find this part ( 50-046 teflon needle bearing)... is this supposed to fall out when i remove the front end of the airbrush or is it hidden inside the main body?
 Ok so i tried reassembling it again and on the second attempt my airbrush just decided to work... seems to be working fine now but that was just the first session
My question is do i have to go back to the store and look for that mentioned part or is it in the body of the airbrush where new guys like me can't get at?
Thanks.
 (damn time to build a airbrsh booth... i dont like this headache...)
    August 2005
Posted by Phil_H on Monday, February 11, 2008 4:49 AM
The needle bearing is buried down the threaded hole that the head screws into. It's factory fitted and is not meant to be user-serviceable, meaning that installing or removing this part is a "return to base" job.
My understanding is that the manufacturer has a special tool used for setting or removing this part, and that under normal circumstances it should not fall out on its own. It can be dislodged by overzealous cleaning and reportedly has been successfully reinserted by a number of users, but as mentioned above, it's not usually a user-accessible part.
Your airbrush may not have worked "out of the box" for a number of reasons, but frequently this happens because of an incorectly set needle or a loos needle locknut. Once you have these things sorted out (and it sounds like you have), it should be near bulletproof.
    February 2008
Posted by Dementiak on Monday, February 11, 2008 6:15 AM
Awesome, Thanks for the detailed reply Phil_H.
Just wanted to make sure so i could replace it if necessary and it sounds like i don't have to go through the trouble.
Now that i'm not worrying about faulty equipment I can get on to the next step... practice.
(while waiting for a reply i managed to build an airbrush booth out of some old canvas boards... I'm going to attach  a generic bathroom air vent fan which i had lying around, the only thing left is to wire the switch and plug. hopefully no more headaches Smile [:)]
