There are other factors involved also.
Does noise present a problem? If not, I would go with an industrial type compressor as you can use it to fill your car tires, run an impact gun to remove your car wheels, etc.
If you need something quiet there are many good compressors from $100-$1,500 depending on what you want.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
