Future as a gloss coat?
    February 2008
Posted by GeorgeF on Saturday, February 23, 2008 11:52 PM
I just read the article in FSM about airbrushing. In the special section Airbrush Gallery Top Tips one of the modelers mentioned Future as a gloss clear. My question is Is that Future floor wax that he is refering to?
Thanks in advance
George
    May 2005
Posted by Bgrigg on Sunday, February 24, 2008 8:29 AM
That's the stuff, George! Only now it's call Pledge with Future Shine. Future floor finish is nothing more than a clear acrylic and can be brushed on (self levelling) or sprayed on. Our own Swanny wrote the definitive article of Future http://www.swannysmodels.com/TheCompleteFuture.html.
It's also great for dipping clear canopies and you can also mix Tamiya X-21 Flat Base to make dull coats. The mixing chart is in Swanny's article.
BTW welcome to the forum!
Bill
So long folks!
    February 2008
Posted by GeorgeF on Sunday, February 24, 2008 9:19 AM
Thanks Bill. I wasn't sure. I will check out that article. TY for the welcome. By what I have read so far, I will be using this forum for reference alot.
George
jwb
    February 2006
Posted by jwb on Sunday, February 24, 2008 11:37 AM
Thanks in advance
George
And don't let anybody fool you that it can also be used for floors..... complete urban myth! Big Smile [:D]
Welcome to the forums.
Future is great. In addtion to the uses listed above, I've even used to to attach P/E parts to kits.
It makes decals go on easier, and makes all those lovely panel lines possible.
Even makes instrument panels look good- add a drop to each dial to simulate glass.
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
Posted by scalefly on Monday, February 25, 2008 7:32 PM
Just started back into scale aircraft models, and I tell you what George, everything you hear about using Future is true!  Experiment around with your airbrush pressures, I have found 10-15 to be a good range so far.  Once you start using the Future, you'll find its an awesome material for model builders, and I found out about on FSM forums.  Take it from a fellow New England'r, you find tons of great info on here!
    October 2007
Posted by Summit on Monday, February 25, 2008 10:38 PM
Jon, are you referring to using the Dried Gloss Coat or Using Future as a Decal Setting Solution ?
Sean "I've reached nearly fifty years of age with my system." Weekend GB 2008
