James,
The Medea cleaner is good but you can make your own cleaner for much less money.
Mix 2 parts distilled water, 1 part Windex, and 1 part Simple Green.
It works great!
The Super Lube is fantastic and I would not go without it.
It helps smooth the action of the airbrush and stops paint from drying to the needle. I have two airbrushes in the garage right now with acrylic T-shirt paint in them, and the bottles still attached to the siphon tube from the last time I airbrushed with them which was about 2 months ago, and they still work like I just cleaned them.
I would call that pretty impressive.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
