Brush painting - enamels or acrylics?
    May 2007
Posted by RTimmer on Wednesday, July 9, 2008 10:12 PM
Hello all,
For better or worse, I'm restricted to brush painting as there is no good place in my home to set up an airbrushing rig.  I've searched and read a number of threads on brush painting in the forum, and I'd like to get some feedback on which would be better for brush painting (in general) - acrylics or enamels?  It seems that enamels will require greater attention to ventilation and possibly the use of a face ventilator - what are your recommendations for safe use of enamels?
For context, I do mostly naval and space subjects, with the odd aircraft.
Thanks, Rick
    August 2006
Posted by HawkeyeHobbies on Wednesday, July 9, 2008 10:31 PM
Well my take is if you can brush paint enamels you can certainly airbrush acrylics in the same space. One can use a shopvac as their particle/dust/vapor collector for work in a small area. I've done that before, purchased an extra hose to plug on the exhaust side of the shopvac and stuck it so it would blow out the window. With acrylics you should have minimal vapor issues.
Now if you just can't facilitate an airbrushing setup, there are pros and cons to painting with either...just invest in good brushes, not cheap ones. Take care of them and they'll do well by you...also try various paints to see what works best for you.
I like Tamiya acrylics and Testors enamels. I airbrush and brush paint with both.
Gerald "Hawkeye" Voigt
