What'd I do wrong ? - Decals Shrivelling
Posted by Bossman on Saturday, November 29, 2003 10:25 AM
On a recent build, I used the same method that I usually do for applying decals and coating with Testor's Dullcoat. But this time the decals shrivelled up after I applied the Dulcoat. (?)
I brush painted with MM Acrylic, one or two coats of future to gloss the surface, applied decals, a coat or two of Testors Decal set solution to get them down, (at this point I don't remember whether I hit them with an additional coat of future) then sprayed dullcoat on. It always worked in the past with good results.
This is the first time I have made a Hasegawa model. Is there anything different about the decal base for these guys that would cause this ? Any other ideas as to what may have caused the problem ? I'm without a clue.
Posted by berny13 on Saturday, November 29, 2003 12:27 PM
Did you wait long enough for the decals to fully dry and set? If not applying dull coat would cause then to react and shrink.
Berny
 Phormer Phantom Phixer
On the bench
Posted by Swanny on Saturday, November 29, 2003 12:50 PM
Testors dull coat is a lacquer based material and can cause damage to decals. I reccomend using Polly Scale clear flat instead - much safer. Also you should give the decals 24 hours to completely dry down before attempting a final sealant.
Posted by Bossman on Saturday, November 29, 2003 7:50 PM
Thanks guys,
I'm goin from memory - which has never been really good - but I'm pretty sure I let them go for a while. But If it was on a weekend - I may have tried to get back to it before a full 24 hrs went by.
Is the Poly Scale an acrylic based material ? If so - I'd much rather use something that isn't quite as chemically nasty as the Dullcoat.
Just a note to Swanny - That's an absolutely gorgeous PB4Y !
Posted by Swanny on Saturday, November 29, 2003 8:15 PM
Yes, the Polly Scale product is acrylic. Low VOC and non-reactive. I used to use the Testors products but switched over about three years ago and have never looked back.
