Crystal Kote
    April 2008
Crystal Kote
Posted by zapme on Saturday, January 15, 2011 2:19 AM
Hi everyone,
This has probably been discussed here before, but this is my first time on the Decal page. My query today is; Can Crystal kote ( I haven't purchased a can yet) matt be used to seal older decals. And how thick a coat would this put on the decal. Is it water proff?
cheers - Leo
My Blog - leoslatestbuilds.blogspot.com
On the workbench: 1/72 Airfix De Havilland DH88 Comet , 1/35 Trumpeter M1A1, 1/35 Tamiya Tyrannosaurus Rex, 1/8 (?) vinyl C3PO brand unknown
    December 2003
Posted by hkshooter on Saturday, January 15, 2011 7:34 AM
I've never used it but.....
I'd test it on something before spraying it on your project. Maybe an old guiney pig model or something to make sure it won't eat the decals.
If it seems ok then the thicknesss of coating will be up to you. A dusting might be ok but a wet coat may eat the decals. Just test some more.
I looked around a bit and it seems as if the stuff is potent smelling so ventilate good. Most references to the product indicate it's for "interior use only" so that tells me it's not water proof.
If you havent bought a can yet and arent famliar with it why not purchase something you've used before? Just sayin.
    April 2008
Posted by zapme on Saturday, January 15, 2011 6:37 PM
hkshooter,
The reason is for the price as a large can, far out weighs the cost of the hobby brands, and you get about 3-4 times the amount more. I want it mainly to seal old decals, but now you've got me thinking, I could also use it as a final matt covering. And you are right, test and more test. I just don't want to buy it and then fine out it is useless.
cheers - Leo
    March 2010
Posted by ACESES5 on Monday, January 24, 2011 1:12 PM
Zapme: I have used Crystal Coat over decals have had no probluems you will get a dull semi gloss finish simalar to what an egg shell looks like, you don't need a heavy coat one or two passes should be good. I thin my Crystal Coat about 80% crystal coat 10% thinner.              aceses5              in the works Roden Pfalz D.III 1/32 scaleWelcome Sign
    April 2008
Posted by zapme on Tuesday, January 25, 2011 3:27 AM
Thanks for the reply ACESES5,
My poison is WWII aircraft so the matt finish is spot on. I guess I will have to be careful to cut right next to the decal to minimise silvering.
Cheers - Leo P
Posted by Don Stauffer on Tuesday, January 25, 2011 9:14 AM
I used to use Dullcoat or Glosscoat, depending on the finish I wanted.  But these both seem to have a strong "shrinking" action that makes the decals curl a lot.  They are hard to apply on strongly convex surfaces.  A couple of times now I have used clear Polyurethane, and it seems to work well with decals and less curling.
