What Don said, Plus I have used on armor and they look great, make yourself a few sizes of burnishing tools (or buy them). I take old retractable pens, remove the spent cartridge, fit and cut various sizes of sprue and insert into the opening where the writing tip is when being used, then mix and pour some quick set epoxy into the barrel and allow to set,screw pen body back together and you have a relitivly inexpensive burnishing tool. I cut at an angle so as to be able to "coax" transfer into recesses as needed.
