Decal Application Video up here...
    January 2006
Posted by Paul Budzik on Thursday, December 4, 2014 9:26 PM
Paul
    January 2006
Posted by Paul Budzik on Thursday, December 4, 2014 9:27 PM
deleted
Paul
    March 2010
Posted by Nathan T on Saturday, December 6, 2014 11:53 PM
Excellent video Paul! Great tips on dealing with all the potential decal issues. I know of others who always trim off the excess carrier film, and I do this myself sometimes when the film is old or too thick or goes much too far beyond the decal, but is it always necessary? Even on high quality decals and small stencils? I've found just a little bit of carrier film can help the decal blend in to the clear gloss coat.
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, December 7, 2014 12:03 PM
I do have one question though. Aren't you suppose to let the decal dry between coats of Micro Sol, Micro Set, and Solvaset? Other than that, that is one of the best video on decal application ever. Bravo.
    January 2006
Posted by Paul Budzik on Tuesday, December 9, 2014 12:46 PM
I think if you move through the process while the decal is stable enough not to distort when you blot it with the damp towel, you will have better success at not trapping air underneath.  Getting the decal to look like part of the surface is not a passive process, they benefit from some coaxing.
Paul
    January 2005
Posted by Watchmann on Tuesday, December 9, 2014 9:45 PM
Thanks for another great video, Paul!
I have a question about the syringe you used to punch the rivets.  Is the tip of the syringe flattened square to it's length, or at a bevel?
matt
    January 2006
Posted by Paul Budzik on Tuesday, December 9, 2014 11:58 PM
Matt,
The end is cut square to the length and then you can sharpen the edge by beveling from the inside or outside depending on the size of the rivet that you want.
Paul
Paul
    January 2005
Posted by Watchmann on Wednesday, December 10, 2014 8:24 AM
Ok, thanks Paul.  That's what I had assumed.
