Decals wrap around small part - how do I glue part after?
LDF
    August 2017
Posted by LDF on Wednesday, August 23, 2017 8:47 PM
My first model in probably 40 years, so this is probably way beyond my capability, but thought I'd ask.
Building a 1/72 scale F-16 which has several small missiles like AIM-9s, which have small decals that wrap around the missile. Since I have to apply the decal first, I can't figure how to glue the part to the plane, since where it makes contact is covered with the decal. Do I scrape off the decal where I need to apply the glue? Or do I put a topcoat on (like Future) over the decals and glue it then?
Posted by Tojo72 on Thursday, August 24, 2017 6:26 AM
Just glue it,the decal isnt going to stop the glue from working,I would use just a little spot of CA glue.
Posted by Bish on Thursday, August 24, 2017 6:40 AM
Tojo72
Ditto Anything thats been painted i use CA for.
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, August 24, 2017 8:13 AM
Glue, paint, then decals. How hard is that?  Of course clearcoat to seal in the decals too.
Posted by Tojo72 on Thursday, August 24, 2017 8:48 AM
Do you mean paint and decal the missles after they are glued to the aircraft ?
Posted by Don Stauffer on Thursday, August 24, 2017 9:39 AM
I scrape away decals from bond areas the same way I scrape away the paint from those areas.  I use variously a #11 blade, a needle file, or drill a depression through surface into plastic with pin vise and small drill.
    September 2012
Posted by GMorrison on Thursday, August 24, 2017 9:57 AM
Have you put the decals on the bombs yet? They never fit right.
Posted by Tojo72 on Thursday, August 24, 2017 10:36 AM
Dont worry about scraping anything ,a 1/72 missle will hold just fine with a spot of CA
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, August 24, 2017 1:01 PM
Tojo72
LOL! No, I meant glue the missile halves together, paint, then decal. Then a shot of clearcoat to seal in the decal before attaching to the kit.
LDF
    August 2017
Posted by LDF on Friday, August 25, 2017 12:12 AM
I was hoping to avoid the CA glue since the parts are so small I'm afraid I won't get them aligned properly before it sets up. Which CA glue has the longest working time?
    January 2013
Posted by BlackSheepTwoOneFour on Friday, August 25, 2017 8:24 AM
Who says you have to use CA glue? I use regular thin liquid glue myself. Works just as good IMO.
Posted by Don Stauffer on Friday, August 25, 2017 10:04 AM
Use gel CA. I use it for two reasons.  First, the slower set time, second, the fact that you do not need a perfect fit, it is gap-filling.
