Tips for working with dry transfers?
Posted by ponch on Friday, August 6, 2004 8:32 PM
Hi all,
I'll be using a set of dry transfers for the first time on my next project. Since I have only worked with decals so far, I have some questions, for example, are transfers supposed to be applied on a glossy surface, just like decals? Do you have to protect the paint job underneath to avoid leaving marks from the rubbing?
Any tips you can share will be greatly appreciated!!
Posted by Anonymous on Friday, August 6, 2004 8:38 PM
Well, I think protection is more in makeing it so the paint doesn't get stuck to the dry transfer sheet (had it happen a few times... I need to use protection,ne? )
Anyway, clean the area as well before putting them down, also had problems with that...
I think that's all I can add here..... Don't have the best experience with them...
Posted by rjkplasticmod on Friday, August 6, 2004 8:46 PM
Dry transfers don't need a gloss surface since you are transferring inks& there are none of the issues associated with water slide decals such as silvering or bubbles from trapped air. You shouldn't have to press hard enough to release the transfer to damage the surrounding paint. Gentle rubbing with a rounded tip burnishing tool should do the trick. Main issue with dry transfers is getting it EXACTLY where you want it before transfering. No second chance with these.
Regards, Rick
Posted by wibhi2 on Friday, August 6, 2004 10:56 PM
Dry transfer will pull up with clear tape if you get them in the wrong place or miss aligned (used to do alot of letraset in school many, many, many full moons ago). Just have a few extras laying around for those "OOPsies"
If you are doing complete words, it helps to lay it out on lined paper (backing side up)
then back it with clear tape before transferring to the model. Other wise Akuma and Rjkplasticmod has a handle on it.
3d modelling is an option a true mental excercise in frusrtation
Posted by djmodels1999 on Saturday, August 7, 2004 9:03 AM
And if there's any weird surfaces, you're better off transfering the letters onto blank decal sheet first! A cat of Future to seal them, then you can use Microsol/set to get the decal in place.
Posted by Anonymous on Thursday, August 12, 2004 8:30 PM
Obviously, proper alignment is critical, since no adjustment is possible after you apply them. In order to make sure that you have rubbed the entire transfer on properly, I use a blunt-tipped pencil to burnish them. The graphite of the pencil tip moves smoothly across the backing paper and leaves a mark where you have traced, so that any area left unburnished can be easily seen and redone before you attempt to remove the backing paper.
