is this right
    August 2004
is this right
Posted by JLerch2 on Thursday, August 12, 2004 7:49 PM
if you guys could check this...
microsol -- getting the decal to form around curves?
microset -- for setting?
future -- gloss coat for the decals to stick to, used for flat models and then a flat clear sprayed after your finished?
thx
Posted by rjkplasticmod on Thursday, August 12, 2004 8:02 PM
You pretty much got it right. Micro Set should be applied to the model in the area where the decal will go & then apply the decal to the model. The Micro Set will soften the decal and help it to adhere & also settle down some. Micro Sol is a more powerful solvent that will soften the decal much morel than the Set solution & is applied over the decal & greatly assist in getting the decal to conform over irregular surfaces & compound curves. Future is used as a gloss coat prior to decaling. For a flat finish, some flat topcoat can be done after everything has cured for a day or 2. Polly Scale flat works great for that purpose.
Regards, Rick
    August 2004
Posted by JLerch2 on Thursday, August 12, 2004 9:55 PM
thanks!!! you guys are great at this forum... everyone always answers questions and with a lot of detail
