Need Colored Strip Decals -- Pronto!
    April 2005
Posted by Thunderbolt379 on Tuesday, April 25, 2006 8:41 AM
Hi all,
This is my first post to the decals board. I have a project well along and have always meant to do some detailing with colored strip decals, basically cheat lines on a hull, a bit like old fashioned rally-stripes on cars. I went to my huge box of decals, confidently expecting to pull out Superscale Trimfilm sheets in the right colors, and discovered my memory was playing tricks.
I checked on the web but couldn't locate a website for Krasel Industries with a Google search -- has their site been taken down???
I need black and red strip decals or solid color sheets from which I can cut stripping. Do other companies make equivalent products? Where might I look for something along these lines?
Best wishes,
In haste,
TB379
http://worldinminiature.blogspot.com/
Posted by Anonymous on Tuesday, April 25, 2006 9:08 AM
you can spray the colors over a clear decal film and make your own,i've done it and it worked fine
    April 2005
Posted by Thunderbolt379 on Tuesday, April 25, 2006 9:35 AM
Hi Ione,
Yup, that's always a good method, I used it just recently, but the film I had for that project was pretty old and the adhesive must have oxidized as it rally didn't want to stick anymore. I have some newer clear film, but I can't find it -- that's the penalty of moving house...
TB379
    December 2005
Posted by PZL P.62 on Thursday, May 4, 2006 8:20 PM
I would just design the strips with paint and then print them out...
Posted by djmodels1999 on Sunday, May 7, 2006 3:00 AM
Red and black lines are available from Decadry, the manufacturer of  rub-on dry transfers (possibly from other manufacturers of those transfers too).  Easy to apply.  Cheap.  I use them mostly on my airliners to make the 'walk' lines on the flying surfaces.
    February 2004
Posted by chris hall on Saturday, May 20, 2006 3:23 AM
 djmodels1999 wrote:
Red and black lines are available from Decadry, the manufacturer of  rub-on dry transfers (possibly from other manufacturers of those transfers too).  Easy to apply.  Cheap. .
And even easier to apply if you rub the stripes down onto clear decal first, cut them out, and use as a waterslide decals. The white stripes and arrows on the side of the drop tanks of this 'what-if' VVIP Harrier:
were done using this method.
Aslo, in Europe at least, it's fairly easy to find stripes of coloured decal. Fantasy Printshop, in particular, do them in a wide range of colours and widths for not much money. All the striping on this Dragon Rapide, except for the tail flash, came from this range:
Cheers,
Chris.
Cute and cuddly, boys, cute and cuddly!
