- Member since
April 2005
Posted by T_Terrific
on Friday, June 30, 2006 9:59 AM
OK:
- Using a pair of small scissors, if you have one of the larger ones with optional markings, etc, first cut the decal sheet into groups, that is the decals you want, the decals you don't want, the insignia markings vs. the cockpit detail markings, etc.
- I always try to start with the biggest decal on the sheet, which usually is the wing marking/insignia. This way, I get the feel for the quality of the decals I am using as well as it being a safer item to "warm-up" with.
- If the surfact is matt, due to a flat colored paint, I paint a gloss clear coat over the panel/area where the decal is to go to enable ease of positioning.
- Having an X-Acto type knife, a small bristle brush, and some paper towels ready, I dip the subject into a soup mug with tepid tap water in it, holding it by a tab that I left on one end when trimming the decal. After about ten to fifteen seconds, I set the wet decal on a hard surface.
- I then dip the bristle brush into the water and wet the area on the model where the decal is to go, and usually by then the decal is ready to slide.
- Next I check to see if the decal is ready to slide, and edge the paper backing down to the model, sliding one edge of the decal off the paper onto the model's surface, holding it "on the spot" with a wet finger (the decal will tend to stick to a dry finger), carefully pulling the backing from under it, letting it "flop" onto the model's surface.
- I then dip the small brush into the water, and stroke the bubbles and wrinkles out, gently "nudging" the decal into position if it needs further aligning, as wel as using the brush tip to help the decal go down into any grooves if needed.
- If the decal is to form over a compound curved surface or over a bump on the model, I normally let it dry before doing anything else, letting the edges "hang out".
- Once it is dry where it will not slide, I then take the X-Acto blade and/or the small scissors, and make cuts where necessary if needed to conform to difficult curved surfaces, and re-wet the edges with the small brush, gently stroking the loose ends down.
- Then, if the decal seems a bit heavy, and has had trouble conforming to surface details, I apply a decal setting solution to it, again brushing the details with the wet brush, and let that dry. You have to be careful with this stuff, because if you use it on a flimsy decal, it can pucker and ruin it.
- After it is dry, I then decide which and whether I with to apply a clear-coat over the decals, if I am not otherwise doing a finishing clear-coat to the model in either a gloss or a dullor a satin finish. Clear coat is nice when the decals want to fall off after they set a while, as well as protecting them from other damage.
- Now as for the type of damage that can occur to decals and how to fix it, after the "disastor has abated", and you see what you got left, I usually resort to a small paint brush and find the matching color in Testors acrylics, and touch up the rough edges after any trimming I find necessary.
Hope this helps
Tom T
Tom T
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
