First use of decal softner
jwb
    February 2006
Posted by jwb on Saturday, July 15, 2006 6:49 PM
I used a decal softening solution for the first time today- Polly S decal softening solution.
Things were going well. There was a slight wrinkling, but I'd expected that from what I read here on the forums and other places. It was looking really good- I could see it pulling down into the panel lines, etc.
Now, I have a very bad habit of thinking "Wow, that looks good! I bet I can get it just a bit better." And that's usually the point I need to stop and walk away.
Sadly, I did not.
So, I'm just showing this and asking to confirm what I believe I've discovered....
This is a result of using too much decal softner, right?
Any tips on using Polly S decal softening solution? (And if the tip is "Jon you used too much" I'm OK with that since it will confirm what I think was the problem. Wink [;)])
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
Posted by Anonymous on Saturday, July 15, 2006 7:45 PM
the decal looks as if the corner lifted and twisted a bit,other than that it would have been fine,,if it was down when you started,you know the answer,,,at least it's an easy to come by decal
are you positive that corner was all the way down and adhered well?
jwb
    February 2006
Posted by jwb on Saturday, July 15, 2006 7:51 PM
Yeah, I'm pretty sure. I htink it may have been a two fold problem- over use of the solvent, and I used a q-tip. I think it may have "gripped" it when a dry portion came in contact with the decal. But it just sorta stretched and distended.
I think next time I'll try a brush in stead of a q-tip.... what do you think?
Also- should I let the decal dry some before applying the solution? I did it right afterward.
Jon Bius
Posted by Anonymous on Saturday, July 15, 2006 8:08 PM
well,,,here goes my unconventional method,but it seems to really work for me
after the full future coat has cured,i use white vinegar brushed on where the decal will go and also a little on the decal itself while it's still on the backing......when it's loose and ready i slide it on and use a 1/4 brush (wet) to work the bubbles out ,if you find that you need to move the decal,now is the time,just wet the brush and use it to get up under it to loosen it back up ,,,,move it and brush out the bubbles,,,,,let it dry for about 15 minutes and then if it's not sinking into the detail on it's own,brush on the solvent (call me crazy,but i still use 90% rubbing alcohol),,,when the decal bubbles up DON"T TOUCH IT!!,,,,wait until the next day and shoot the last coat of Future before final weathering.
hope thishelps
    May 2005
Posted by Bgrigg on Saturday, July 15, 2006 8:56 PM
Poor Jon,
The cardinal rule of decal softener is to apply and NOT TOUCH!
lone's approach is fairly sound (and most softener IS vinegar!), though I wouldn't use rubbing alcohol (otherwise known as Isopropyl), though I'm more a coward than he a fool! Wink [;)]
If thats the wing insignia and is 1 1/2"x 13/16" I have a couple I can post to you. Just PM or Email me the addy. The only thing I ask in return is that at some point in the future you do the same or similar for some person in need.
The reason I have extra decals is I ended up buying a Cutting Edge decal sheet to replace some decals that I had a similar mishap with...
So long folks!
jwb
    February 2006
Posted by jwb on Saturday, July 15, 2006 9:35 PM
 Bgrigg wrote:
Poor Jon,
Thanks for the offer! I actually have one that will work just fine, but I appreciate the offer. ( i love this place..... Big Smile [:D]
I've finished applying the decals, and I seem to have found a way that works for me- luckily with only the one hard-learned lesson.
The first time (when it "blew up"), I applied the solvent to the wing, then the decal, then lightly worked out the bubbles, then applied the solvent with the q-tip- and tried to work the bubbles out again. I think the combination of the solvent drench and the rough "grip" of the Q-Tip (broke that cardinal rule! Wink [;)]) did me in. No- check that, I don't think it did, I KNOW it did! LOL
On the next try, I applied the decal to the surface without the solvent (it was already Futured and cured), then worked out the bubbles thoroughly, and worked out most of the water. In other words- I got it set about as good as I could get it without chemical help (for the model, not me!).
After it was already pretty tight, I applied a light coat of solvent. I then let that dry for 10 minutes or so, and checked where it hadn't tightened down. I then applied a little more only in that area, and then repeated as needed.
And that seemed to be the trick- doesn't it always seem to be the case in this hobby- slow down, work carefully and apply only small amounts at a time. Smile [:)]
The rest of the decals snugged down super tight, and except for a few minor spots, look darn near painted on.
I think a few more decal sessions and I'll be looking good!
Jon Bius
    May 2005
Posted by Bgrigg on Saturday, July 15, 2006 10:24 PM
You'll be looking good? I thought you were applying the decals to the aircraft! Clown [:o)]
So long folks!
    February 2006
Posted by gtother on Saturday, July 15, 2006 10:27 PM
I recently began experimenting with alcohol (70%).  Its goin well and its always around.  I could not ever find any name brand stuff like Microsol or Polyscale, so I just practiced with vinegar.  I prefer alcohol now that ive tried it.  I hate the smell of vinegar...
                                           -graham
jwb
    February 2006
Posted by jwb on Sunday, July 16, 2006 5:55 AM
Wait.... the guy at the LHS assured me I'd be handsomer er usin' the stuff! I won't?!?!?!
Jon Bius
jwb
    February 2006
Posted by jwb on Sunday, July 16, 2006 5:56 AM
                                           -graham
Hmmmmm......
So what do you use for your decals?
LOL
Had to say it.....
Jon Bius
    February 2006
Posted by gtother on Sunday, July 16, 2006 1:28 PM
OOOHHH were talking about decals...
    July 2003
Posted by schulerwb24 on Monday, July 17, 2006 12:04 PM
So gtother-  what is that plane you have posted under your name? Looks neat.
