decals & open doors/access panels
    June 2004
Posted by rgamba on Monday, August 14, 2006 8:59 AM
I am just starting a 1/72 Tamiya spit (BofB) and would like to model it with some open access panels.  Can anyone advise what the best method is when the situation calls for the decal to be placed over the access panel which you intend to leave open.  Is it best to wait for the decal to dry before cutting or should this done beforehand.
Thanks in advnace for any suggestions
Robert
Posted by tyamada on Monday, August 14, 2006 10:28 AM
I would let the decals dry before cutting them.  Use a brand new #11 Xacto blade.
    May 2006
Posted by MortarMagnet on Monday, August 14, 2006 11:03 AM
Yes.  I do everything I would normally do to set the decal, then cut.  Even a very slightly used blade is risky.
Brian
    June 2004
Posted by rgamba on Monday, August 14, 2006 4:28 PM
I had a feeling that I should wait until dry to perform the surgery but was looking for some confimation - thank you both for your replies.
Cheers
