Solvent solutions
Solvent solutions
Posted by Anonymous on Monday, January 29, 2007 8:49 AM
i was searching at my hobby store's page for any solvent solution, but i dont know many, and no one of them were avaible. do anyone know others thatn microsol, solvaset or mr mark softer?
    March 2006
Posted by Yann Solo on Monday, January 29, 2007 9:36 AM
Vinegar and alcohol!!!!!
Vinegar can be used in place of MicroSet.  It helps getting the decal into place.
Alcohol can be used to replace Micro Sol.  It will soften the decal a little bit and help it conforms to bumpy surfaces.
 If you heat those products a little bit, it will work better.
No matter where you go ....... there you are.
    February 2006
Posted by ruddratt on Monday, January 29, 2007 10:41 AM
Yann is 100% correct. I asked the same question and followed his suggestion. They work great, and are much more economical.
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
Posted by Anonymous on Monday, January 29, 2007 2:37 PM
ok, thanks. if it works for me, i'll be saving a good bunch of money. thanks again
    March 2006
Posted by Yann Solo on Monday, January 29, 2007 2:58 PM
I noticed that MicroSol is working better than alcohol though.  But vinegar is just as good as MicroSet.  You might want to get some MicroSol for the toughest jobs.  If it's not available in your area, you might want to add a bottle of it on your next "online" purchase of a kit.  Most online shop have them stock.
Posted by Anonymous on Monday, January 29, 2007 6:32 PM
lets see. the next time i'll be able to buy online will be... uhm... when i reach 18 years old.
maybe i'llfind at orlando. do someone know about any hobbyshop in orlando?
    January 2006
Posted by PatlaborUnit1 on Sunday, February 4, 2007 9:14 PM
Agreed. I use VERY warm water on my Tamiya decals adn they settle right in with little or no solvent.  Heat is the solution:  I use an electric "candle warmer/coffee cup warmer" plate with a thick crockery bowl for my decal water adn it works every time!
 Good luck with it
David
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
