Micro Sol dissolving Future
    April 2004
Posted by Screaminhelo on Wednesday, April 4, 2007 4:19 PM
Has anyone else experienced this?  I have just started using Future as an undercoat for decals and have found that if I don't pay attention and get the solution off fairly quickly, the Future bubbles and peels off.  I let the Future cure for a couple of days.
Mac
Mac
I Didn't do it!!!
    May 2005
Posted by Bgrigg on Wednesday, April 4, 2007 5:16 PM
Yes, this is a fairly well known problem, and it crops up every week or two. Future is an acrylic  and using a solvent on it is not recommended.
So long folks!
    July 2003
Posted by Circuitrider on Wednesday, April 4, 2007 10:07 PM
Check out this thread:  /forums/760300/ShowPost.aspx
Maybe it'll help some.
    January 2003
Posted by Triarius on Wednesday, April 4, 2007 10:08 PM
Sign - Ditto [#ditto] IIRC, Microsol contains several alcohols which will attack Future, and some other acrylics—always a good idea to test on scrap first.
    April 2004
Posted by Screaminhelo on Thursday, April 5, 2007 11:14 AM
Thanks for the info.  I had tried searching the forums, but I guess I wasn't searching foor the right terms.
Mac
Mac
I Didn't do it!!!
Posted by Anonymous on Thursday, April 5, 2007 4:52 PM
oddly enough, here's an example of two "wrongs" making a right.  i'm not a big fan of future floor wax but i decided to use it this time to a) give it a try and b) put on 5 layers of a cheaper gloss coat since doing that with polyscale would pretty much use up a whole bottle if not more.  the plane had decals and i used micro set+sol as always.  result:  no problems.
 why?  i put the decals on over the paint without the gloss underneath and cover the decals with gloss.  i did notice that the sol (or set, one of them) would dissolve the paint a bit but it wasn't that serious so i just let it re-dry.
on the good new side, future will go on over micro-sol'ed decals with no problems. Smile [:)]
    April 2004
Posted by Screaminhelo on Monday, April 16, 2007 4:39 AM
Just to let folks know, a small change in technique helped out.  Got the decal in place, wicked away water and then applied Micro Sol.  Decals went down just fine.  The Micro Sol did start to dissolve Future but just leaving it to cure again worked out just fine.
Mac
Mac
I Didn't do it!!!
