Custom made decals website
    June 2007
Posted by tiald1 on Saturday, June 23, 2007 10:38 AM
Hi there
There's a great new website that makes custom made decals
www.parkes682decals.piczo.com
had some decals of him,superb quality if you want decals this is the man to see
Cheers Andrew
    January 2007
Posted by Viper Has The Lead on Tuesday, June 26, 2007 10:04 AM
Hi Andrew,
                  Thanks for the link.  Have bookmarked it as I will be in need of something like this v soon.
Regards
Mick C.
"All modern aircraft have four dimensions: span, length, height and politics. TSR.2 simply got the first three right." Sir Sydney Camm
    June 2007
Posted by Col_Shaggy on Sunday, July 1, 2007 12:23 PM
I was just about to ask about custom decal makers when I found this post.
My question now, though, is if he uses Testors inkjet decal papers and bonder or if they are produced similar to professionally made kit sheets?
If your not familiar with the Testors sheets you design your own graphics through a program like Paint Shop Pro, or Windows Paint, etc. Then you print the image off on the decal paper, with an inkjet printer, and spray the sheet with bonder that protects the ink. The sheets have decal film across the entire sheet (as opposed to the film just around the decal piece itself) and come in clear or white films. Then you can cut out the individual decals and apply them just like regular water slide decals.
The problems I've run into on my cannibal kits is that whatever the paint color of the model is will show through the clear films unless the decal is absolutely black and no hue in between, unless I use the white filmed sheets. The problem with using the white films is that many of the markings I use are fairly open and spindly, so I can't cut out the white from the empty sections inside the markings with out weakening the overall decal.
If Parkes's decals sheets are the product of Testors inkjet gear does anyone know where I can get my custom graphics turned into kit style decal sheets?
There are no masterpieces. Everything is training. - Me
