weathering Decals
    January 2004
weathering Decals
Posted by mooseman on Tuesday, October 2, 2007 8:04 AM
Hello everyone
here's a question I'm sure someone will have an answer to.
 I am in the process of finishing an Italeri 1/72 Ju 88 C-6 in a heavy winter camouflage for the Russian Front and have recently applied the decals.  What struck me as odd is despite the rather effective camouflage effect of my airbrushing (no boasting intended - just pleased with the results!) the decals look exceptionally new in contrast.  Anyone have any ideas/effects that might tone the decals down to the level of the winter camouflage?  Bear in mind the decals are already on the aircraft so that might hinder any applications!
 hope someone can help
All the best
Moose
    January 2006
Posted by rubaru on Wednesday, October 3, 2007 11:03 AM
You might try a 10:1 mix of clear dullcoat and whatever the background color is (white, grey, etc).  It will lay down a very thin coat of background and might dumb down the decals a bit.  What do you think?
    January 2004
Posted by mooseman on Thursday, October 4, 2007 1:42 AM
Sounds worth a try - I pesume by "clear dullcoat" a flat varnish will suffice?  It certainly would blend the decals in with the surrounding finish - I'll give it a go.
Many thanks
    January 2006
Posted by rubaru on Thursday, October 4, 2007 11:23 AM
Well, I'm not sure what "flat varnish" is.  I've always used that term with wood stains.
What I do know is that Gunze, Testors, and Floquil all make a clear flat liquid paint (as opposed to an aerosol can) that you can mix with color paints..  I suppose you should check if it's acrylic or enamel, first!  I went to greatmodels.com and searched for clear flat and came up with about 9 different products.
    January 2004
Posted by mooseman on Thursday, October 4, 2007 4:47 PM
Many thanks - I'll let you know how it turns out
Regards
    September 2003
Posted by Daywalker on Saturday, October 6, 2007 9:56 AM
I had a similar problem with my desert '109.  After applying all of the decals, I thinned some Tamiya buff to about 20% paint and 80% thinner and gave the entire model a light dusting.  Best to do it slowly and build up the effect.  HTH!
Before:
After:
Frank
    August 2006
Posted by HawkeyeHobbies on Saturday, October 6, 2007 11:59 AM
If I am correct the winter camo was applied in the field. The aircrafts markings were already in place. If that is correct, then the decals should be applied before the winter effect is done.
Gerald "Hawkeye" Voigt
    January 2004
Posted by mooseman on Thursday, October 18, 2007 1:49 PM
Thanks to all the ideas - particularly like the effect of your 109 Daywalker, nice job on both the painting and the toning down.  I had the same thoughts as you Hawkeyehobbies with effect to a field applied camouflage.  I thinned the distempered white and lightly airbrushed the entire model then took a few dozen cotton buds and lightly tainted with thinners gave quite a vigorous rub down over the decals, particularly along the lines of the airflow and panel and rivet detail, it greatly enhanced the bedded down effect of Micro sol & set.  Smugly (if that is a word!) pleased with the result and now looking forward to Telford and the nationals on the 10/11th November.
 Once again thanks for all your responses.
 Mooseman
