Hello All -
New to all this but hoping get good at it soon.
Got a decal dilemma: I am trying to apply a sheet of Scale-Master decals but must be doing something wrong. I will probably need to do a closer trim job, but I did a test decal where I soaked it about 30 seconds, pulled it out with tweezers (on an unprinted corner) and then tried to push the decal off gently with a wet Q-tip.
Instead, I managed to flake off the image on the decal - it just eroded away.
What am I doing wrong? I had read in some other forum that a drop of liquid detergent in the water may help loosen the decal. I also read about how you can "paint" a solution on the decals to strengthen them.
Any ideas? Thank you very much!
- Mike
