Sand, abrasive papers. What sort do you use?
    February 2009
Posted by DogTailRed2 on Tuesday, June 30, 2009 6:04 AM
Hi,
what are the best abrasive papers for general sanding and then polishing in preperation of painting. I'm finding general diy shop papers a tad too course.
Thanks,
Ted.
    August 2005
Posted by Phil_H on Tuesday, June 30, 2009 7:48 AM
I just use hardware store "wet and dry" papers in 400, 600, 800, 1200 and 2000 grits. Use wet for best results.
Posted by Tojo72 on Tuesday, June 30, 2009 3:48 PM
I have fallen in love with Squadron Sanding Sticks,coarse,medium,and fine,all are useful.
    September 2003
Posted by Daywalker on Tuesday, June 30, 2009 9:55 PM
I use 3M wet or dry, bought at the local hardware store in 400, 600, 1200, and 2000 grits.  I also use those 4-grit nail files from Walgreens. Thumbs Up [tup]
Frank
Posted by MikeV on Wednesday, July 1, 2009 11:24 AM
 DogTailRed2 wrote:
Hi,
Thanks,
Ted.
Why would you want to polish the plastic before painting? That would defeat the purpose of having some "tooth" for the paint to adhere to.
What are you painting? I like a green Scotchbrite pad like you wash pots and pans with.
It scuffs the plastic to provide better adhesion of the paint but is probably 600-800 grit equivelent in sand paper I would guess.
    August 2006
Posted by HawkeyeHobbies on Thursday, July 2, 2009 8:38 AM
Some of that tooth as you call it will show through with different paints. If you're doing a flat camo job or a high gloss colored one chances are you'll fill those scuffs with no problem. But if you are doing a thin skinned NMF or an acrylic painted scheme they might stick out like a sore thumb.
If you need tooth...then prime.
I use nail sanding and polishing sticks, rarely do I dig out the papers.
Gerald "Hawkeye" Voigt
Posted by MikeV on Thursday, July 2, 2009 10:21 AM
True Gerald, I was assuming paint and not a NMF finish which HAS to be smooth.
The Scotchbrite pads leave such light scuffs in the plastic that I have never had a single problem. It is much easier to scuff the bare plastic, wipe it clean and paint then it is to prime, wait for it to cure and then paint.
    February 2009
Posted by DogTailRed2 on Thursday, July 2, 2009 10:40 AM
Hi,
thanks for everyones help.
I bought some 1200 grit, 800 grit and 250 grit wet and dry from my local ironmongers which did the trick.
When I said `polishing` I meant just to sand the plastic to a smooth finish so I could paint it. I didn't mean to actually polish it with a liquid or whatever.
 Cheers,
 Ted.
    August 2009
Posted by nico86326 on Saturday, August 22, 2009 8:40 PM
Honestly I just use the emery boards and fine polishing sticks from the womans cosmetic section in any store. You can cut them to any size you want and they work great for filing pretty much anything. The polishing sticks you get for nail files have a very fine grid to them almost equalivent to a 1200. You can also wet them.
Just food for thought.
Mein Leben für mein Land. On the Bench: Academy Tiger 1 Early.. Fully detailed.. and pain in the butt
