paint booth
    February 2011
paint booth
Posted by Sawdustbob on Saturday, March 26, 2011 2:40 AM
I would like to build a paint booth of my own.  Building the body of the booth will be no problem but I need to decide weather I want a downdraft or overhead vent?  What kind of lighting and filtering and any other hints any of you might have?  Also if anyone knows of a source for smaller 110 V squirrel cage type blowers I would appreciate it.
    April 2004
Posted by Jon_a_its on Saturday, March 26, 2011 3:49 AM
Hi & welcome
Lots of people have built their own, the 'erm 'consensus' if there is one, suggest the following recipe works well.
Perspex top and/or sides with strip lighting,
Furnace filters or cooker-hood filters (or even just a cooker hood!) at the rear of the booth,
With an extractor vented to the outside behind that.
MANY people suggest either a shrouded fan with the motor out of the airflow OR one suited to shower booths is a good idea.
Key point is to prevent the (small) risk of the motor sparking causing VOC's to flashover, esp with Enamel, Alcohol, Cellulose/Laquer & rattle cans. I think Acrylics could also burn, not all are water based.
Some Uk builds here for thought.
http://www.militarymodelling.com/forums/postings.asp?th=21434
http://www.militarymodelling.com/news/article.asp?a=3661
http://www.the-waaagh.com/forums/?showtopic=24154
 http://www.militarymodelling.com/forums/postings.asp?th=35366
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    February 2011
Posted by Sawdustbob on Saturday, March 26, 2011 4:02 AM
Thanks for the links.  THe sparking issue was why I was going to use the blower type fan since the motor is usually not in the path of the airflow.
Posted by Don Stauffer on Saturday, March 26, 2011 9:52 AM
There is a third choice.  You can draw the air to a plenum at the rear, with a vertical filter (I used a furnace filter).  My objection to updraft type is on my last version I mounted a fluorescent lamp in the top.  I have to believe the downdraft type will cause more junk to settle on model.
    April 2008
Posted by zapme on Tuesday, March 29, 2011 3:37 AM
Hi sawdustbob,
Thought I'd add my 2 cents worth here. The below booth is my own home made one. for the body I used my old busted microwave, gutted it, attached some wood board on the bottom and drilled multiple holes through it. I then went to my local hardware and purchased an overhead light and bathroom ceiling fan. I cut the appropriate hole on the top for the light and attached the fan underneath. both items are plugged into the power socket. lastly I added a door in the front to stop the dust getting onto the model.
Cheers - Leo
My Blog - leoslatestbuilds.blogspot.com
On the workbench: 1/72 Airfix De Havilland DH88 Comet , 1/35 Trumpeter M1A1, 1/35 Tamiya Tyrannosaurus Rex, 1/8 (?) vinyl C3PO brand unknown
    October 2009
Posted by krow113 on Monday, May 2, 2011 12:47 AM
Search this forum ,I have responded to this question numerous times, as well as others.
Thank you ,Krow113
    January 2005
Posted by daveinthehat on Monday, May 30, 2011 12:01 AM
I made mine from .040 aluminum with a baked white finish. I have an explosion proof fan from Granger. It's a downdraft and uses a standard size furnace filter. I keep a coat of car wax on the inside to make it easy to clean. It works great. I have an under cabinet light mounted on top. There's a piece of Plexiglas between the light and the booth.
