Glue tips question
    December 2010
Glue tips question
Posted by atlrus on Thursday, September 22, 2011 8:13 AM
I am using the metal needle glue tips (these ones: http://www.amazon.com/gp/product/B003L1MJWC  ) and was wondering if someone could enlighten me on the best way to keep the glue from drying in the needle.
Posted by RESlusher on Thursday, September 22, 2011 8:21 AM
Depending on the size of the muzzle you could stick a needle in it.  That's what I do with the little Testor's plastic tips I use with their tube glue.
Richard S.
On the bench:  AFV Club M730A1 Chaparral
On deck:  Tamiya Marder 1A2
In the hole:  Who knows what's next!
    February 2007
Posted by mitsdude on Friday, September 23, 2011 2:38 AM
What kind of glue are you using?
    December 2010
Posted by atlrus on Friday, September 23, 2011 7:20 AM
Medium flow instant glue, I am not sure about the brand, something Hobby Lobby sells.
    July 2011
Posted by prush on Sunday, September 25, 2011 12:28 PM
Air is you enemy.
Anything to plug the opening will do the trick.
A needle, a toothpick, a piece if wire, a thumbtack.
Any will do the trick
Posted by Don Stauffer on Monday, September 26, 2011 8:51 AM
Keeping nozzles of CA glue open is one of the problems using the stuff.  If you stick a pin in it, there is nothing to prevent the pin eventually being glued into the nozzle- have had it frequently happen. If you use the cap some brands provide, then the nozzle clogs with hardened CA.
However, in the later case, the nozzle can then be opened again by piercing with a pin.  But do not put the pin back in!  Put the PE cap back on.  I always use brands that provide a polyurethane cap- I find that works better over the long run than a pin, but eventually even the capped nozzles may harden too far to use.
Be sure to cap as soon as done. I have had tubes harden completely, inside tube, long before it is empty.  So I buy only the smallest tubes/bottles of CA glue.  Large containers are no savings if stuff hardens in container.
Posted by RESlusher on Monday, September 26, 2011 1:42 PM
That's why I like the new Kazy Glue container with the brush in it.  I haven't had any problems with it hardening up.
Richard S.
    June 2009
Posted by kermit on Monday, September 26, 2011 1:49 PM
I know it sounds REALLY dangerous but i usually warm the needle up over a flame. Since it is the absolute tip of the needle clogging theres no real danger of igniting anything.
The needle will "pop" clear and i cool the tip down with some saliva. Been doing it for years and consider having an argument with my wife infinitely more dangerous...
Richard
EDIT: shoulda read better.... I was referring to the plastic glue i use, not CA.... I use a brush bottle of that stuff... never a prob
"Success is the ability to go from one failure to another with no loss of enthusiasm." - Sir Winston Churchill
    December 2010
Posted by atlrus on Monday, September 26, 2011 2:20 PM
kermit
Richard
Lol, This has been my solution so far, I was just trying to find something better than burning it all the time :)
    August 2005
Posted by EdGrune on Monday, September 26, 2011 8:37 PM
Ditch what you're using and check these glue tips
http://resinshipyard.com/pages/tip_pages/glue_tips.html
If the directions are beyond your skill, Darren at RS will be glad to sell you a packet.
Start with a length of R/C control linkage sheathing.   Heat over a flame and stretch like sprue.   Stretch to the desired diameter (yes, the inner opening remains when stretched).
The material costs are about $2.35 for a 24-inch piece which makes several dozen glue tips.  I've successfully used these tips with Hobby Lobby-brand CA.
When the tip clogs (every couple of weeks) snip off about 1/8 inch of the tippet and continue gluing.
    January 2011
Posted by stymye on Friday, October 14, 2011 10:07 PM
some more tips ,, don't touch what you are glueing or get debris into the tip
keep it well away from any accelerator bottles
moisture(not air)  activates it,, some people store the bottle in a baggie.
don't store it in a fridge than open it right away(condensation will form inside)..lol
use a high quality pure brand,, the typical hobby brands are full of filler and junk  something like Balsa usa gold will last forever without  hardening up on you unexpectedly
