Masks
    July 2014
Masks
Posted by Bakster on Friday, October 14, 2016 3:28 PM
Hi guys. I am working on a project where I need to mask some very small and irregularly shaped areas. Using tape would require trimming with a sharp knife, and that could potentially ruin the already applied paint layer below. In addition, it is hard to cut curved edges at that scale. Over the years I have tried using some of the rubberized liquid masking products and I hate them. They do not give a nice clean edge. They are often tacky, they stick really well to the piece, and they stretch when removing them often fracturing the paint that was applied. You end up having to score the edges and again, jeopardizing the paint below.
Has anyone found a product or method that works really well as a mask? Ideally, I would like to find a liquid mask that does not stick and stretch when you remove it.
If not... no worries. Just putting feelers out to see if there is a better way.
    September 2003
Posted by checkmateking02 on Saturday, October 15, 2016 2:04 PM
What are you masking, Bakster?  It usually takes different techniques for different projects.
For some of the tricky parts of USS North Carolina in 1/700, I used some poster tack.
Sometimes you can combine masking tape with poster tack.
For planes, I've bought aftermarket masks, then traced around the patterns, made a photo copy, and taped the pattern over masking tape.  Then I cut out the pattern with scissors and apply it.  I've found that sometimes the purchased masks don't stick too well, but regular, cheap household masking tape will do OK.  I usually buy Duck brand masking tape.  Below, I used the old Eduard Spitfire masking set, which I don't think is available anymore.
If there's no aftermarket masks available, you can use a painting guide or profile to enlarge a mask to the size you need.
You'll probably receive other suggestions, too; but these have worked pretty well for me.
Good luck with your project!
    August 2016
Posted by scaler on Tuesday, October 18, 2016 1:02 PM
Frisket film can, probably, be used, too:
http://www.grafixarts.com/products/frisket-film/
It is made of polyesther and polypropylene and commonly sold in art stores. It is attached to smooth backing paper and comes in rolls. You can easily cut it with an X-acto blade tip to any shape without cutting through the backing paper. The masks are reusable and won't lift the paint. Airbrish artists use this film all the time. You can use it with acrylics for sure, yet enamels or lacquers may not be compatible.
Some think this is actually fun!
