CA glue holder I made
Posted by MikeV on Sunday, July 11, 2004 2:24 PM
I made this simple CA glue holder that works great for doing small projects without using a lot of CA.
I took a piece of 1/4" plywood and stuck some foam tape to the bottom for grip and then CA glued one of those tapered washers that you see in the picture to it. I then cut about a 1" square of aluminum foil and press it into the washer forming a small cup to hold a drop or two of CA. I then put a piece of masking tape on each end to keep the foil in place. All you have to do when you are finished is pull the foil off and replace it with a fresh piece.
I hope this may come in handy for some of you looking for an easier way to hold a few a few drops of glue without wasting a bottle cap each time.
The pieces used:
Ready to use:
Posted by maddafinga on Sunday, July 11, 2004 3:04 PM
Good idea Mike! I usually just tear off a small piece of masking tape and put a few drops on that. I kind of like this better as I'm sure I wouldn't be putting my right forearm into the glue as often with your idea.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by MikeV on Sunday, July 11, 2004 4:21 PM
Thanks Josh.
I also just put a beer bottle cap over it to keep from getting your arm in it and it also keeps it from drying up as fast when I have the ceiling fan going in the room.
    December 2012
Posted by FreedomEagle1953 on Sunday, July 11, 2004 8:05 PM
All very good ideas ... Smile,Wink, & Grin [swg] ... thanks for sharing ... Approve [^]
FreedomEagle1953
Chicago, IL area
"keep on building 'em ... but don't glue your fingers together"
Posted by Anonymous on Monday, July 12, 2004 7:02 AM
great idea mike, another one for the records.
Posted by MikeV on Monday, July 12, 2004 7:42 PM
Thanks everyone, I appreciate the kind words.
Actually just putting a drop or two on a piece of masking tape as maddafinga mentioned does work well also, but I find that a lot gets wasted as it spreads around and dries. This little holder I made keeps it all in the same 1/4" circle which makes it easy to dip a toothpick or a Microbrush in it. Wink [;)]
Posted by Anonymous on Tuesday, July 13, 2004 6:10 PM
This is a great idea Mike.
Murray
Posted by Anonymous on Friday, July 16, 2004 1:49 AM
cool...wheres my wood....
    May 2003
Posted by qmiester on Saturday, July 17, 2004 8:30 AM
I use plastic cups (the ones they give you pill and liquids in at the hospital) for mixing my paints and several years ago noticed that they had a depressed area in the bottom (when you turned them over) that is about the size of what you have with the upholstry washer and tinfoil that you made (which by the way is a great idea). I place my CA in the recess and it works great - and when I'm finished and the CA is dry, I can still use the cup to mix paints in.
Quincy
Posted by MikeV on Saturday, July 17, 2004 10:14 AM
Thanks Quincy.
That is a good idea also. Thumbs Up [tup]
Posted by Anonymous on Wednesday, July 21, 2004 8:17 AM
Thats a great idea. I made one out of cardboard and a bottle cap. It works great too.
    December 2003
Posted by scottrc on Wednesday, July 21, 2004 8:25 AM
Super, I hate it when I put a drop or two on a flat surface and it bleeds all over. I'll try this idea.
Scott
Posted by Anonymous on Wednesday, July 21, 2004 10:37 AM
MikeV,
the way i do it is everytime someone in our house pop a pill (take medications), i alway save the medicine tablet packing specially with the wider cavity and use this to put a few drops of glue, after done, just throw is away. now, on my inventory are about fifty of these.
Posted by Anonymous on Wednesday, July 21, 2004 1:54 PM
Great ideas, i'll have to try one (or all).
Posted by Anonymous on Tuesday, August 10, 2004 6:24 AM
I like it Smile [:)] I like it Big Smile [:D]Cool [8D]Big Smile [:D]
http://greatlakesmodeling.com
Posted by Anonymous on Tuesday, August 10, 2004 1:30 PM
Really cool idea, I am going to raid the stockroom here at work in a few minutes. This place/forum is a great place. I wish I had this a long time ago when I first started builing. Maybe I would be alot better than I am right now.
Ted
Posted by Anonymous on Monday, August 16, 2004 12:25 PM
Good idea indeed. As soon as i get my fingers unglued, i'll have to make one. Big Smile [:D]
    July 2004
Posted by wbill76 on Tuesday, August 17, 2004 5:22 PM
Some very innovative solutions for dealing with CA...I've been using just the little tiny bottle of Testor's CA that I picked up at the LHS but this type of container sounds much more user and clean-up friendly!
