Temporary holding agent?
Posted by Anonymous on Tuesday, April 22, 2003 9:13 PM
Hi people, just a question. I've experimented with tacky material for holding canopys on during painting, and the best thing I've found is my small stash of "sticky stuff" from those magazine inserts. Now I find that my mailing label for Finescale is held on with it. What is this stuff??? It works great, but I can't locate it in it's liquid form. Any help will be appreciated.
    January 2003
Posted by shermanfreak on Tuesday, April 22, 2003 10:15 PM
Another item you may want to try is called Sticky-tack. It's made by 3-M and is used for sticking posters onto walls and other things. Might just do the trick.
Posted by Anonymous on Tuesday, April 22, 2003 10:28 PM
I think the stuff they use is a form of "rubber cement". My mom used to use it all the time for scrapbooking and stuff like that. The way it works is if you just put it on one of the two surfaces that you want to glue together it will not permanently bond and you will be able to remove them later. If you put it on both surfaces then it is supposed to permanently bond them together. Crafters like it because unlike white glue it does not wrinkle and distort paper products.
Ray
Posted by naplak on Tuesday, April 22, 2003 10:49 PM
Try jeweler's wax... it is a soft sticky wax that cleans off easily with alcohol. As your local jeweler where you can get some!
www.naplak.com/modeling ... a free site for modelers www.scalehobby.com/forum/index.php ... a nice Modeling Forum
Posted by Anonymous on Wednesday, April 23, 2003 5:59 PM
white glue: add water then it disolves. u can thin it with water also
    July 2013
Posted by modelmaker66 on Wednesday, September 18, 2019 4:27 PM
Can white glue in small amounts be used then re wetted to come loose?
