Where Can I get Casting numbers?
Posted by Anonymous on Monday, October 18, 2004 8:47 AM
Hey guys,my first questions to you:
After the last issue of FSM I would like to know where I can get Casting number stencils or dry-transfer sets for German tanks,aircrafts and ships and maybe British and American as well?
Could you give me direct link,if possible?
THANKS A LOT in advance!!!
    July 2003
Posted by Foster7155 on Monday, October 18, 2004 8:57 AM
I saw a great tip online somewhere where the author used the embossed numbers and letters from old model sprue for his casting numbers. The numbers would be carefully (and thinly) cut off the sprue and glued into position on the appropriate casting. There were a couple examples and they looked very good to me.
I've never seen casting "stencils" online, but dry-transfers are available from hundreds of online stores. Whether any of the transfers are for casting numbers specifically will require some searching.
Enjoy your modeling...
Robert Foster
Pensacola Modeleers
    July 2003
Posted by zokissima on Monday, October 18, 2004 2:52 PM
As per the above note, a good cheap way to get casting numbers is to use the ones that are on all parts sprues. As for dry transfers, they're available from a variety of manufacturers, and are offered by pretty much any good online hobby shop.
Good place to start is Squadron and Great Models ( www.squadron.com and www.greatmodels.com respectively)
Posted by wibhi2 on Monday, October 18, 2004 3:00 PM
I kinda think that III.JG7_rosenberg was also referring to the font type used by german manufactuer's, which is IRC, a bit different than something that you would find
on a US/UK made item.
UK/US casting no's could easily (albiet carefully and patiently) be cut off sprues
check with your local art supply store for dry transfers
3d modelling is an option a true mental excercise in frusrtation
Posted by Anonymous on Tuesday, October 19, 2004 4:09 AM
Thanks guys, that was kind of I was looking for samll production numbers on items like wheels of tanks and so on.
Thanks ,saved the internet links in my folder!
