you are correct Mike. It can cause chemical burns on the skin.
If you get it under your fingernails, you will wish the Lord would come and take you.
MEK is also the active ingredient that cures polyester resin in fiberglassing. It will work as stated in the post but it is nasty stuff.
Find a plastic distributor, and get a pint of weld-on #3. Thats all you need. I have been using the same can of weld-on for a year.
