Rubber Cement for masking?
Posted by Anonymous on Monday, August 29, 2005 1:04 AM
Hello all. I was wondering if anyone has used rubber cement for a masking material? Maybe on the clear plastic of windows.
I was just curious if it would pull off paint or not. Anyone have any experiance with it?
    January 2004
Posted by Ali1kj on Monday, August 29, 2005 11:53 AM
Simple answer...it will and it will and it will...use silly putty or tape or Liquid mask
AJ
Posted by Anonymous on Monday, August 29, 2005 2:52 PM
Silly putty.....? never heard that before, but hey, I'll try it.Propeller [8-]
    May 2003
Posted by qmiester on Monday, August 29, 2005 7:13 PM
A lot of railroad modelers use rubber cement to get a chipped paint effect on buildings. Paint the base coat the color they want showing thru the chips, add splotches of rubber cement when paint dry, apply coat of top color and when dry use tape to pull the rubber cement off the surface leaving a chipped appearance. My suggestion would be to experiment with it on an old model or a piece of styrene.
Quincy
    January 2004
Posted by Ali1kj on Tuesday, August 30, 2005 9:09 AM
Hi
And they use a lot of enamel paints...a lot of "plastics" guys now use all acyclic which has a weaker adhesion (esp within hrs) and who waits :)
Use the masking liquids for the job, they last a long time (so don't moan about cost )..eg Mr Maskit or Humbrol Maskol...and it does not pull your brass off either :)
Alasdair
Posted by Anonymous on Sunday, September 4, 2005 9:03 PM
hey guys..i was just wondering if that blue masking liquid really works.. is it advisable to use it? i was wondering if paint sticks to it. i use tamiya enamels btw. thanks a lot
    January 2004
Posted by knight667 on Tuesday, September 6, 2005 5:03 PM
I use it for masking complex windows and canopies, mainly on armor. I've tried it as a camouflage mask, with poor results. Rubber cement, also, gave poor results (marred the finish on my paint...enamels, btw).
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
Posted by Anonymous on Tuesday, September 6, 2005 5:24 PM
I've never had good luck with Liquid Mask-plus it ruins brushes, and rubber cement is just bad (toxic) news.
Posted by Anonymous on Tuesday, September 6, 2005 7:47 PM
I tried rubber cement and it left a ragged line. I was told that the cement can also attack plastic so I guess I was plain lucky!
The Humdrol stuff is good for sealing the lines on masking tape etc. I use it on the locater pins, holes in kits where parts attach so I don't have to scrape the paint away.
It removes easier than rubber cement as well. Generally I apply it with a cotton swab on large areas or a toothpick depending on the application, but it can be removed from brushes with a thinner I believe, just not sure what though!
