Where can you buy RTV casting silicone or rubber to make molds??????????
Posted by Anonymous on Friday, November 4, 2005 11:28 PM
Hi I'm wanting to know where can I buy RTV rubber or silicone atQuestion [?] I don't know if Michaels, or Joanne Fabrics carries it. also is there a good brand for making model kit moldsQuestion [?] Is there a certain kind of rubber or silicone to make molds for partsQuestion [?] I could use some help cause I'm looking on buying the RTV locally first unless I have to order it over the net.
Thanks,
Erik
    January 2003
Posted by gburdon on Friday, November 4, 2005 11:49 PM
Erik:
Michaels does carry it. RTV that is (at least here I found it) JoAnn Fabrics I have never seen it in there.
You could check if there is a retailer near you from this link.
www.modelbuilderssupply.com
They have all the goodies for casting in a one-stop shop.
Check the yellow pages as well there may be a company around you that does casting work that could direct you localy.
Cheers;
Gregory
VETERAN - (Noun) - Definition - One who signed a blank cheque as: “Payable to The People of Canada, Up To and Including My Life."
Posted by Anonymous on Friday, November 4, 2005 11:58 PM
Thanks, GREG!!! A friend of my fathers who builds model kits for retirees is getting ready to put in production our first model kit and I need the rtv to make the molds. What is the best brand of rtv to use to make a 1/72 scale cargolifterQuestion [?] I'm planning on using resin or styrene to make the kit. The only resin that I have seen at my hobbyshop is clear, and the hobbyshop didn't have the catalyst on the shelf. Can I get resin and styrene at Michaels or JoAnn FabricsQuestion [?]
    January 2003
Posted by gburdon on Saturday, November 5, 2005 12:10 AM
Erik:
The link to MBS has the best list for RTV. The first package shown is the type I use and it is so simple to use right out of the box. The reference pamphlet that is shown there is another little gem to have on the reference shelf.
As far as which resin to use. I will assume you are not casting clear parts. I use ALUMILITE its a two part resin and it hardens to a cream colour. It is great stuff and it is so incredibly easy to use. I believe my last box came from Model Builder Supply.
As far as resin at Michaels if they do not have it. Ask if they will order it for you. 90% of the time here the Michaels by my home orders items for me.
If you need further information let me know.
Cheers;
Gregory
Posted by Anonymous on Saturday, November 5, 2005 1:04 AM
How much did the ALUMILITE cost from MBSQuestion [?]
Posted by Anonymous on Saturday, November 5, 2005 2:00 AM
Eric.
There is nothing like the BEST, only the best suited application z or y.
RTV rubber and Silicone have different properties and thus are suited for different applications.
Rather than worrying about the mold material, have you considered the following:
1.) Parts per mold
2.) Layout per mold
3.) Which resin will be needed for the best casting result(curing times)
The above will be affected by how your casting method: manual, spinning, rotor, vacuum, etc.
Either way I would order about 3~4 times the expected amount initially. as you will need a few tries before the molds are correct(no trapped air, good pouring channels, etc).
Posted by SNOOPY on Monday, November 7, 2005 11:18 AM
Micro Mark has a starter casting set and other casting supplies like RTV.
