How to effectively remove raised panel lines..
Posted by Anonymous on Saturday, December 17, 2005 8:51 PM
the only technique i know of is sanding.. but i have models with a lot of detail. how do i remove the panel lines that are close to them? i'm afraid to damage it while sanding.. can anyone give me technique's on how to deal with this? thanks.
Posted by ckfredrickson on Saturday, December 17, 2005 9:35 PM
One way would be to carefully scrape them away using your hobby knife/scalpel/razor blade, although this tends to leave flat spots.
Sometimes I use the raised panel lines as a guide for scribing... the act of scribing both removes raised line and leaves a scribed line.
    April 2005
Posted by wing_nut on Saturday, December 17, 2005 10:58 PM
While I have not built anything with a riase panel line... how much different can that be from a mold line?  I scrape them with a knife as described above then a light buff with a Scotch brite scouring pad to reduce chance of a flat spot .
Marc
Posted by Anonymous on Sunday, December 18, 2005 10:37 AM
I use a seam scraper from, I think, MicroMark. Beautiful little tool, I removes the raised grid from a 2500th scale Enterprise D easily. It had two "heads" with each one angled a different direction.
Posted by Anonymous on Monday, December 19, 2005 12:57 AM
can i make this tool using a chisel blade?(flat head xacto blade) i dont know where to get the Micro mark tool, it's not available locally from where i live right now.
Posted by Anonymous on Monday, December 19, 2005 1:19 AM
i have a scriber tool, do you mean scribe "beside" the raised line? or above the raised line? killing two birds with one stone.. will the raised panel line be enough for a guide? or do i still have t use dymo tape? thanks
Posted by jcfay on Monday, December 19, 2005 9:35 AM
No one has mentioned this bit of wisdom yet, so I figured I might as well mention Swanny's contribution on this topic:
http://www.swannysmodels.com/Scribing.html
I've used his tips a bunch.  I'm pretty sure he even has a specific build that covers how he removes raised panel lines and then scribes over them, don't remember which build however.  Good luck Smile [:)]
Posted by ckfredrickson on Monday, December 19, 2005 10:05 AM
Either on top or beside the raised lines is do-able.
I don't think the raised panel line will be enough for a guide (especially if you're scribing on top of them)... you'll need something else (dymo, steel ruler, eraser shield, etc.).
Posted by Anonymous on Tuesday, December 20, 2005 11:33 PM
ok. thanks again brothers
Posted by Anonymous on Wednesday, December 21, 2005 5:55 PM
The seam scraper I have is the Squadron one, like this:  http://www.hobbylinc.com/htm/squ/squ10203.htm
Well worth the money and easy to use.
