Tenax - 7R ... yea or neah?
Posted by gedenke on Friday, June 29, 2007 12:53 AM
I recently tried some Tenax-7R and quite frankly, I'm not impressed. Maybe I didn't use it right but I feel like I got a better bond with my Testor's plastic cement. What are your experiences with it?
-Geoff There is an art . . . to flying. The knack lies in learning how to throw yourself at the ground and miss. — Douglas Adams, 'The Hitchhikers Guide to the Galaxy'.
Posted by ajlafleche on Friday, June 29, 2007 10:23 AM
Works great for me. Did you follow the instructions on the bottle?
    January 2003
Posted by Triarius on Friday, June 29, 2007 10:41 AM
I use either an old, fine brush (I replaced the large, clunky one in an old Plastruct Pro-weld bottle with a cut-off of a dead 000 spotter.) or a Touch-n-flow applicator. Press the seam together, touch with applicator or brush. Capillary action will draw the liquid along the seam. I generally do between two and three inches of the seam at a time. Continue to hold parts together for about half a minute.
Tenax is really just methylene chloride, aka dichloromethane. You can buy larger quantities at any plastics supply and manufacturing outfit. I buy it by the gallon that way (lasts a long time). One manufacturer is Caseway, product name is SC-125. They also make inhibited varieties that have a slower evaporation rate.
Posted by rjkplasticmod on Friday, June 29, 2007 6:49 PM
I've been using Tenax for a long time & it works great for me.
Regards,  Rick
Posted by gedenke on Friday, June 29, 2007 9:40 PM
Ok, I feel really stupid asking this, Sign - With Stupid [#wstupid] so let me swallow my pride and get it over with. Are you supposed to glue the joint with normal model glue first, attach the parts, then apply the Tenax? 'Cause I didn't, I figured it was supposed to "weld" the plastic together. Ok, you all can start making fun of me now! Propeller [8-]
    May 2003
Posted by DrewH on Friday, June 29, 2007 9:41 PM
I agree with Triarius. I get my glues from the local plastics supplier. Follow those simple instructions and you'll have no problem. Big Smile [:D]
Take this plastic and model it!
    May 2003
Posted by DrewH on Friday, June 29, 2007 9:49 PM
(laughing......kinda?) No. The Tenax is the glue. The point I see was missed is you need a slight gap when applying it. I'm talking about a 64th of an inch gap. Or better yet apply from the inside of the two parts.
Try this. Get two pieces (ie: wheel halves or airplane fuel tanks) and hold the two together lightly with an elastic band. put a razor blade in the seam opening a gap. Using a small brush or applicator, apply a small amount to the edge of the razor at the plastic. Pull out the razor and gently squeeze together. If a couple of small "plastic bubbles" come out - it's perfect. If nothing does, no problem. Wait a few moments and see if you can get it apart. If the glue got onto the edge of the plastic, it should be bonded. Ta-Da! Try it a few times untill you comfortable on some spare parts. Hope that helps a bit more.
 Drew
Posted by gedenke on Friday, June 29, 2007 10:22 PM
Thanks, Drew, that does help. I'll try it again with your tips in mind. Problem is, when I tried it before, I spead it on like glue and joined the parts. I was a bit disgusted when said part literally fell of after what should've been adequate drying time.
    May 2003
Posted by DrewH on Friday, June 29, 2007 10:33 PM
AH, the infamous drying Tenax. It's really a solvent not a glue in the way you know it. The Tenax will soften the plastic then evaporate. If you wait too long, a few seconds is too long, the Tenax evaporates and the plastic re-hardens before it can bond. It takes a bit of getting used to, but once you do you'll never go to anything else.
    September 2003
Posted by Daywalker on Friday, June 29, 2007 11:57 PM
I used the Tenax for years.  But, recently started using the Tamiya extra thin cement and have had better luck.  Still like the Tenax, just like the Tamiya stuff better.
Frank
    June 2007
Posted by berserker on Monday, July 2, 2007 10:28 AM
does a 'touch-N-flow' applicator work with cyanoacrylate glues too and where do you get that stuff triarius is talking about
Joe Photo Sharing and Video Hosting at Photobucket Photo Sharing and Video Hosting at Photobucket
    January 2003
Posted by Triarius on Monday, July 2, 2007 10:39 AM
 No. CA glues are true "glues." They will set up in any tube applicator (including their own Angry [:(!])
Look in your local phone book for plastics suppliers and fabricators.
    May 2003
Posted by DrewH on Monday, July 2, 2007 10:41 AM
NO. Don't use your touch-n-flow with CA glue. If it dries in there, you need a new one.
I get my glue from a plastics supplier. The ones that sell 4X8 ft sheets of acrylic or polycarbonate. It's normally marked in cans for acrylic bonding. I get mine for about $8 CAD and that fills 4 Tenax bottles. Lasts me a good two years. You can get them in bigger containers, but it evaporates really fast if the lids are not air tight. The longer it sits, the greater chance of it evaporating. It also has a slightly stronger odor to it. HTH
    June 2006
Posted by MaxPower on Monday, July 2, 2007 2:18 PM
I get awesome results with Tamiya glue. I use regular and extra thin.
    April 2005
Posted by T_Terrific on Monday, July 2, 2007 3:17 PM
I find it helps when using a product like this, essentially a liquid plastic welding solvent, it helps to first tack the two surfaces together (like two slightly warped fuselage or wing halves) with a CNA glue gel (I prefer the brushible Loctite gel I get from Wal-Mart), mainly applying it at the locating pins and corners. Then I come back with the plastic welder brush (I use the Ambroid product), running it along the inside seams, wicking it along gaps, etc., and using some tape or rubber bands to clamp the parts until it dries.
Tom Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
    May 2004
Posted by KINGTHAD on Thursday, July 5, 2007 12:29 PM
I used Tenax for a long time and have no problems with it, however Tamiya does evaporate slower and you have a little more time before it sets.
Thad
    February 2006
Posted by ruddratt on Thursday, July 5, 2007 5:32 PM
I just ordered 3 bottles of it based on this post, so it better work! Tongue [:P] Wink [;)]
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    May 2003
Posted by DrewH on Thursday, July 5, 2007 7:55 PM
Mike, we forget to say it doesn't work on bi-planes Laugh [(-D] It's too modern for that.Mischief [:-,]
    July 2007
Posted by Moon Puppy on Thursday, July 5, 2007 8:04 PM
I've picked up the hobby after 15 years. I found 2 bottles unopen and 2 open, all is still as good. Using it now with no problems at all.
Remember, we are told Post Counts don't matter! (unless it's really high)
Modelers' Alliance
    February 2006
Posted by ruddratt on Thursday, July 5, 2007 8:50 PM
LOL!! Laugh [(-D]
    February 2005
Posted by Kevleerey on Saturday, July 7, 2007 10:58 PM
Anyone else having trouble finding Ambroid Proweld? It's backordered several places around here. Production trouble or something maybe? They said they couldn't get an ingredient or something I think.
--------------Kevin
    May 2003
Posted by DrewH on Saturday, July 7, 2007 11:37 PM
Yup, here too. Also Alclad II has been banned from hobby shops. 3 city shops were pinched by the has-mat police. I like keeping a bottle of Pro Weld handy incase of a lid being left off, but no more.
    February 2006
Posted by ruddratt on Sunday, July 8, 2007 12:03 AM
Seriously Drew? Un-freakin'-believable.
Glad I stocked up when I did.
    May 2003
Posted by DrewH on Sunday, July 8, 2007 10:23 AM
Yup, Abbotsford, Richmond and Burnaby shops got pinched. Fortunatly our favorite shop found out and 'hides' his for the known customersWink [;)]
    January 2003
Posted by Triarius on Sunday, July 8, 2007 12:33 PM
That (the ban) is just plain stupid, in the strictest meaning of the term.
    February 2006
Posted by ruddratt on Sunday, July 8, 2007 1:49 PM
He's da man!!!
    May 2003
Posted by DrewH on Sunday, July 8, 2007 4:28 PM
I agree totaly Ross. They focused on Alclad, but didn't bother with the bottles of Testors Laquer thinner, or metalizers. What's the diffrence? Nothing- to this cowboy!Angry [:(!]
Posted by Anonymous on Monday, July 9, 2007 4:50 AM
Why were those products banned?  Are they banned every where?
    April 2004
Posted by Screaminhelo on Wednesday, July 11, 2007 8:01 PM
The Ban appears to be a Canadian thing.  I just picked up some here in Atlanta today and the LHS knew nothing about it.  Try ordering it from the States or getting someone here to send you some.
Mac
I Didn't do it!!!
    May 2003
Posted by DrewH on Wednesday, July 11, 2007 8:37 PM
No, seems to be more of a local thing the more I hear about it. Just some "new to the job" compo employee wanting to make a name for themselves in all likelyhood. I get that it's dangerous, but why they focused on Alclad is anyones guess.
