tamiya re-scribing tool.
    May 2006
Posted by ian lanc on Wednesday, March 5, 2008 5:03 PM
hi lads,
just got my self the re-scriber ! whats the best way of using this thing ? i'm all over the place even if i have a thin panel line and try and make it deeper the damn thing comes out of the grove,  what would be the best way of doing the lines on a nacelle ?
thanks in advance...... ian.
just doing one more model ! thats all.
    May 2006
Posted by ian lanc on Friday, March 7, 2008 9:20 AM
i take it nobody re-scribes panel lines then !! Angry [:(!]
    September 2003
Posted by Daywalker on Friday, March 7, 2008 10:05 AM
Sorry Ian, I have never used the Tamiya one.  I use a seing needle mostly.
Frank
Posted by waikong on Friday, March 7, 2008 2:58 PM
Haven't used that particular tool, but the general consensus is to use Dymo tape. Those old tapes for printing sticky labels, they are thick enough to act as a guide for the scribing tool but flexible enought to wrap around contours, as long as they aren't too small in diameter. Then just go slow and use very little pressure on the first few passes. I usually wind up with 5-6 passes before I get a line I like. The first few passes is just to make sure your later passes don't skip out of the groove. Doing this freehand is almost impossible not to skip out..
    February 2007
Posted by Bioya on Friday, March 7, 2008 3:56 PM
I use a pin vice as a holder for a sewing needle when scribing panel lines. Works for me and most of us have a pin vice on the work bench.
    July 2013
Posted by modelmaker66 on Thursday, February 18, 2016 3:50 PM
gently pull the scriber backwards in the line. Don't really apply pressure let the scriber do the work. You may have to do a lot of pulls bu it should work, putting pressure =causes the jumping
    January 2014
Posted by Silver on Wednesday, March 30, 2016 9:41 PM
I have used it many times and it works fine.The UMM scriber is the best.Thats my opinion.Also, not to get into a situation to scribe lines at all.Purchasing good quality kits is bestOnly scribe the joining lines between parts.Raised panel line kits like monogram and others out there will be about a 100% of Re- scribing.You will need aircraft prints to replicate those panel lines.
