Black Cat Info/Pics needed...
Posted by Jeeves on Monday, August 9, 2004 4:59 PM
I have been to all the sites that come up on Google and Dogpile, but am lacking just a bit of info. I plan on using the salt technique so as to provide some weathering of the flat black paint scheme and was unsure what should be underneath.
I see with the references I have that the typical Cat was blue gray on top and white underneath...my question is were the Black Cat Catalinas painted in the field...or did they come from the Consolidated factories as black?? Also-- would bare metal show up at all, or just the underlying camo?? Thanks!
Posted by BlackWolf3945 on Tuesday, August 10, 2004 3:31 PM
Just wanted to let you know that this hasn't gone unnoticed, Mike. Workin' on it...
Fade to Black...
Posted by Jeeves on Tuesday, August 10, 2004 7:53 PM
Appreciate that Steve...was hoping you might have something Smile [:)]
    July 2003
Posted by Dwight Ta-ala on Tuesday, August 10, 2004 9:21 PM
Oops sorry. Thought you were talking about the Black Tomcat Vandy-1.
    July 2003
Posted by diggeraone on Wednesday, August 11, 2004 6:43 PM
Jeeves,I am working on a black cat.Lobbie had a good post on this subject on page 93 on the aircraft forum.I as refernce mat have used his post and squadrons walk around.That I know of most of the black cats where paint on the field,some at the factory when order as such.Most cats where painted the blue-grey with with underside. The other painting was done in the field and painted to there area.Like Jacksonville used the three coloed scheme,the north atlantic used the two coloed and two grey colors.The pacific used the two color scheme as well as the black.The army air corp.use a green grey scheme,coast guard used two color,black and the all natural.This is about the best I can do for you due to I don't have a scanner,hopely I will have my black cat done by tomorrow.Digger
P.S.you might want to check the history channel.com they may have something on it.
Put all your trust in the Lord,do not put confidence in man.PSALM 118:8 We are in the buisness to do the impossible..G.S.Patton
Posted by Jeeves on Friday, August 13, 2004 1:50 PM
OK.... after some thought and a bit more research-- I went with the blue gray on top. Now-- I would like to try ou the salt chipping technique....where on this bird would the most extensive weathering be?? I know some here have said to weather the hell out of it-- but should there be huge patches of blue?? Or just chipping at leading edges of wings and cowlings and the like?
    July 2003
Posted by diggeraone on Friday, August 13, 2004 3:59 PM
Jeeves,what kind of weathering do you want?As for me I did what Lobbie did with a little differents in techinque.I sparyed painted a base coat of silver then when dryed I did my top coats and sanded heavily.I used a rought grit for heavy weathering paint chipping. Then with a lighter grit[as light as I can get]for buffing.This tech is easy and fun.Now as the weathering goes,the cat was in need of constant paint jobs.Most weathering was at the bottom,this should be weathered a lot also the nose,cocpit area,wing edges with scraches arcoss the wings to the trailing edge,tail areas,elrons,and light weathering with paint chips around and under the enginering area.The outriggers were heavily weathered and engines with cowls.Boy I wish I had a scanner so I can scan some photos to you from my squadron book.I am allmost done with mine and should have some photos posted tomorrow of my build.If you get a chance sreach for Lobbies black cat it might give you some good ideals.Digger
Posted by Anonymous on Friday, August 13, 2004 4:56 PM
Jeeves,
Have a look at pages 9 and 10 of the album 29 Foxtrot which has a wartime pic of an Aussie 'Black Cat', I was given to replicate my 48 scale model, with pix of the model, from top and underneath. Be glad to help with anything on this bird.
Rob.
Posted by Anonymous on Friday, December 3, 2004 3:10 PM
Jeeves, just watched a documentary on Discovery Wings on the Black Cats the other day, they talked about the paint scheme and said it was applied in the field. Hope this helpes. CHIMO!!!
Sgt Al Buttree
Engineers "FIRST IN LAST OUT"
