Aircraft Military Terminology
Posted by berny13 on Thursday, February 15, 2007 3:52 PM
Military Aircraft Terminology
A.  Alpha
  AAF= Army Airfield
  AAR= Air to Air Rocket
  AB= After Burner (Also called Re Heat by the British)
  AB= Air Base
  ABDR= Aircraft Battle Damage Repair
  ABFC= AB Fuel Control
  AC= Aircraft Commander (Pilot)
  ACC= Assistant Crew Chief
  ACES= Advanced Crew Escape System
  Acft= Aircraft
  ACLS= Automatic Carrier Landing System
  ACMI= Air Combat Maneuvering Instrumentation
  ACRP= Armament Control Relay Panel. (Pronounced A Crap)
  ACT= Air Combat Tactics
  ADF= Automatic Direction Finder
  AFB= Air Force Base
  AFCS= Automatic Flight Control System (Autopilot)
  Aft= After (Rear)
  AGE= Aerospace Ground Equipment
  AGL= Above Ground Level (Called Angel by ATC)
  AGM= Air to Ground Missile
  AGPU= Aviation Ground Power Unit
  AHC= Antenna Hand Control
  AIM= Air Intercept Missile
  Air War Collage= Program for senior officers teaching advanced war planning
  Alpha Probe= A vane used to measure pitch (AOA)
  ALS= Automatic Landing System (Runway)
  ALSE= Aviation Life Support Equipment
  Alt= Altitude
  AMRAAM= Advanced Medium Range Air to Air Missile
  AOA= Angle Of Attack
  APU= Auxiliary Power Unit
  ARI= Aileron Rudder Interconnect
  ARM= Anti Radiation Missile
  ASB= Aviation Support Battalion
  ASI= Air Speed Indicator
  ASL= Above Sea Level
  ASM= Anti Ship Missile
  ATC= Air Traffic Control
  ATK= Attack (As in attack unit)
  Aug= Augmentation  Used in conjunction with Pitch Aug (Stab), Yaw Aug (Rudder), and Roll Aug (Aileron).  Part of the AFCS Altitude/Heading Hold system.
  Auto Acq= Automatic Acquisition.  Used with the Radar Boresight Mode.  After three sweeps of the Radar, the Radar will automatically lock on to an airborne target.
  AVTR= Airborne Video Tape Recorder
  AWACS= Airborne Warning and Control System
  AWG= Airborne Weapons Group
  AWRU= Aircraft Weapons Release Unit. (Pronounced A Rue)
B.  Bravo
  Bait and Trap= A flight of aircraft flying low and slow using call signs of bombing aircraft to draw enemy fighters into attacking.  The most successful was Operation Bolo performed by Col Olds of the 8th TFW.
  Ballistic= Missile looses track or lock on and goes un guided
  Ball Ammo= Ammo containing a soft outer casing with a hard core
  Bandit= Identified Enemy Aircraft
  Bar CAP= Barrier CAP
  BCP= Both Cockpits
  BDA= Battle Damage Assessment
  BDHI= Bearing Distance Heading Indicator
  BDU= Bomb, Dummy Unit
  Bear= Rear seater in a Wild Weasel Acft
  Beta Probe= A vane used to measure yaw
  BFM= Basic Flight Maneuvers
  BIT= Built In Test
  Black Box= Flight Data Recorder & Cockpit Voice Recorder
  Bingo= Point of safe return (Fuel)
  BLC= Boundary Layer Control
  BLU= Bomb, Live Unit
  BN= Bombardier Navigator
  Bogie= Unidentified Aircraft
  Boresight Mode= A Radar mode where a very narrow cone from the Radar is transmitted.  The target must be maintained within that narrow cone in order to maintain lock on.
  BRU= Bomb Rack Unit.  Bomb suspension unit allowing up to six bombs or other ordinance to be loaded.  It is similar to a MER except it can carry more weight and is supersonic capable.  Carried by the F-111 and F-15E
  BUFF= Big Ugly Fat Fellow (B-52)
  BVR= Beyond Visual Range
C.  Charlie
  CADC= Central Air Data Computer
  CAG= Commander Air Group
  CAG Bird= Personal Aircraft of the CAG
  CAP= Combat Air Patrol
  Cap= Captive. A non launchable weapon used for training
  CAS= Close Air Support
  CAS= Calculated Air Speed
  CATM= Captive Air Training Missile
  CB= Circuit Breaker
  CBP= Circuit Breaker Panel
  CBU= Cluster Bomb Unit
  CC= Crew Chief
  CCIP= Computer Controlled Impact Point
  CFT= Conformal Fuel Tank
  C/L= Center Line
  Clean off Garbage= Jettison external stores
  CLP= Center Line Pylon
  CND= Could Not Duplicate
  CO= Commanding Officer
  COC= Chain Of Command
  COD= Carrier Onboard Delivery
  Code 1= Aircraft returns from flight with no discrepancies
  Code 2= Aircraft returns from flight with minor discrepancies not effecting safety of flight
  Code 3= Aircraft returns from flight with major discrepancies effecting safety of flight
  Comp= Computer
  CONUS= CONtinental United States
  CP= Cockpit
  CRP= Counter Rotating Propeller
  CSAR= Combat Search And Rescue
  CSD = Constant Speed Drive
  CSD/Gen= CSD & Generator
  CW= Continuous Wave (Radar)
D.  Delta
  DACT= Dissimilar Air Combat Tactics
  Daisy Cutter= Any bomb with a 36" fuse extension so it will explode above ground
  DCC= Dedicated Crew Chief
  DCM= Deputy Commander for Maintenance
  Departure= A condition where an aircraft enters un controllable flight
  Depot= Acft goes through a complete tear down, inspection, and rebuild
  DEROS= Date Estimated Return Over Seas
  Det= Detachment
  DME= Distance Measuring Equipment
  DO= Deputy Commander for Operations
  Drone= A RPV target
  Dumb Bomb= Any free fall conventional bomb
  Dump the Load= Drop Ordinance
E.  Echo
  EBAD= Engine Bleed Air Duct
  ECM= Electronic Counter Measures
  ECCM= Electronic Counter Counter Measures
  EDGB= Engine Driven Gear Box
  Egress= To leave an area or to eject from an aircraft
  EGT= Exhaust Gas Temperature
  ELINT= Electronic Intelligence
  Eng= Engine
  Envelope= Parameters of flight in which an aircraft can operate safely or effectively
  EPR= Engine Pressure Ratio
  ETA= Estimated Time of Arrival
  ETD= Estimated Time of Departure
  ETIC= Estimated Time In Commission
  Eval= Evaluation
  Ext= External
F.  Fox Trot
  FAC= Forward Air Controller
  FBW= Fly By Wire
  FCC= Flight Control Computer
  FCF= Functional Check Flight (A test flight to check aircraft systems)
  FCP= Front Cockpit
  FDBC= Flight Directional Bombing Computer
  FE= Flight Examiner
  Feet Dry= Flying over land
  Feet Wet= Flying over water
  FF= Fuel Flow
  FFAR= Folding Fin Aerial Rocket
  FF Ind= Fuel Flow Indicator
  FL= Flight Level
  FLIR= Forward Looking Infra Red
  FLR= Forward Looking Radar
  Flt= Flight
  FO= Foreign Object
  FOD= Foreign Object Damage
  FOL= Forward Operating Location
  Fox= Fire Missile (Never say fire unless some one is burning)
  FPM= Feet Per Minute
  FUBAR= Fowled Up Beyond All Repair (or Recognition)
  Fwd= Forward (Front)
G.  Golf
   GAR= Guided Aircraft Rocket
   GB= Gear Box
   GBU= Guided Bomb Unit
   GCA= Ground Control Approach
   GCU= Guidance Control Unit
   GD= Gear Door
   GIB= Guy In Back
   GPH= Gallons Per Hour
   GPM= Gallons Per Minute
   GPS= Global Positioning System
   GPU= Ground Power Unit
   Green Flag= US Air Force sponsored electronic warfare training program
   GS= Ground Speed
   GSE= Ground Support Equipment
   GTU= Gas Turbine Unit
H.  Hotel
   Hard Target= Armored vehicles, hardened buildings, or bunkers
   Hard Wing= Aircraft equipped with or without leading edge wing flaps
   HARM= High speed Anti Radiation Missile
   HAS= Hardened Aircraft Shelter
   HDGP= High Drag General Purpose (bomb)
   Herd Sheep= Fighter aircraft push or herd enemy aircraft into a position where other fighters are in position to attack.
   HF= High Frequency
   HiPAC= High Pressure Air Compressor
   HOTAS= Hands On Throttle And Stick
   Horz= Horizontal
   HSI= Horizontal Situation Indicator
   HUD= Heads Up Display
   HVAR= High Velocity Aerial Rocket
I.  India
  IAS= Indicated Air Speed
  IAW= In Accordance With
  IFE= In Flight Emergency
  IFF= Identification, Friend or Foe
  IFR= In Flight Refueling
  IFR= Instrument Flight Rules
  IGV= Inlet Guide Vanes (Eng)
  ILS= Instrument Landing System
  Inbd= Inboard
  Ingress= To enter an area
  Inert= Non explosive
  Inop= Inoperative
  INS= Inertial Navigation System
  Inst= Instrument
  Int= Internal
  IP= Instructor Pilot
  IR= Infra Red
  IRAN= Inspect, Repair As Necessary (See Depot)
  IRGB= Infra Red Guided Bomb
  Iron= Conventional high explosive bomb
  IRST= Infrared Search/Track
  ISA= Integrated Servo Actuator
J.  Juliet
  Jammer= Aircraft used to jam enemy radar sites
  Jammer Pod= ECM Pod
  JATO= Jet Assist Take Off
  JDAM= Joint Direct Attack Munition
  Jett= Jettison
  JFS= Jet Fuel Starter
  JP= Jet Petroleum (fuel) (Followed by a number which specifies the grade of fuel such as JP-4 or JP-7)
  JSAW= Joint Stand Off Weapon
  JTIDS= Joint Tactical Information Distribution System
K.  Kilo
  K-Ball= Cannibalize (Taking parts from one aircraft or equipment to fix another)
  KIAS= Knots, Indicated Air Speed
  KIR= Keyed Interrogation Receiver (Part of the IFF system)
  KIT= Keyed Interrogation Transmitter (See Above)
  KTAS= Knots, True Air Speed
  KTS= Knots
L.  Lima
  LABS= Low Altitude Bombing System
  LAL= Left Aft Launcher
  LANTIRN= Low Altitude Navigation and Targeting Infra Red for Night
  LAPES= Low Altitude Parachute Extraction System
  LAU= Launcher
  Laugh In= Wing Commanders Staff Meeting
  LCP= Left Center Pylon
  LDG= Landing Gear
  LDGP= Low Drag General Purpose (bomb)
  LEF= Leading Edge Flaps
  LES= Leading Edge Slats
  LEX= Leading Edge Extensions
  LF= Low Frequency
  LFL= Left Fwd Launcher
  LGB= Laser Guided Bomb
  LIP= Left Inbd Pylon
  LMG= Left Main Gear
  LMGD= Left Main Gear Door
  Lock On= Radar has acquired a target and is feeding information to a missile
  LOP= Left Obd Pylon
  LoPAC= Low Pressure Air Compressor
  LORAN= Long Range Aerial Navigation
  LOX= Liquid Oxygen
  LRU= Line Replacement Unit
  Lt= Left
MMike
  M= Model
  Maple Flag= Canadian sponsored aircrew air combat training program
  MASI= Mach Air Speed Indicator
  Max= Maximum
  MCAS= Marine Corp Air Station
  MDS= Mission Design Series (B-52H, Bomber, 52nd designed, number eight in the series)
  MER= Multiple Ejector Rack.  Bomb suspension adapter allowing up to six bombs or other ordinance to be loaded.
  MFC= Main Fuel Control
  MFD= Multi Function Display
  MIG CAP= Aircraft performing CAP for strike aircraft
  Mil= Military.  Usually followed by a number which specifies type such as Mil-L-7808 (Engine Oil) Mil-H-5606 (Hydraulic Fluid)
  Mike Mike= Millimeter (As in 20 Mike Mike)
  Min= Minimum
  MK= Mark
  MLG= Main Landing Gear
  MLGD= Main Landing Gear Door
  MO= Maintenance Officer
  MPT= Motion Pickup Transducer
  MR= Main Rotor
  MRP= Miscellaneous Relay Panel (also called Missy Panel)
  MSL= Mean Sea Level
  Mud Mover= Term used to describe ground support pilots
  MWA= Missile Well Adapter
N.  November
  N1= Number one compressor section, low pressure (Engine)
  N2= Number two compressor section, high pressure (Engine)
  NAS= Naval Air Station
  NBC= Nuclear, Biological, Chemical
  NCOIC= Non Commissioned Officer In Charge
  NDAS= Nose Dome Accessory Housing ( A covering that goes on front of engine covering the nose accessory drive section.)
  NDB= Non Directional Beacon
  NFT= No Fine Tune (Missile fails to finalize data from the aircraft Radar)
  NLG= Nose Landing Gear
  NLGD= Nose Landing Gear Door
  NORDO= No Radio (Inop)
  NPA= Non Powered Age (Ladders, work stands, oil and hydraulic service carts, jacks, etc)
  NVG= Night Vision Goggles
O.  Oscar
  O2= Oxygen
  O & B= Out and Back
  Obd= Outboard
  Office= Cockpit
  OGB= Optical Guided Bomb
  OIC= Officer In Charge
  OPAH= Oil Pump Accessory Housing
  OT&E= Operational Test and Evaluation
  Over the wing= Method of refueling using hand held nozzel to fill each fuel tank or cell
P.  Papa
  PACAF= PACific Air Force
  Paint= Radar is tracking several targets
  PAM= Pylon Attachment Mechanism
  PAR= Precision Approach Radar
  PC= Primary Control
  PCA= Permanent Change of Assignment
  PCS= Permanent Change of Station
  PCU= Power Control Unit
  PDM= Programmed Depot Maintenance (Only items contracted will be accomplished at depot)
  PFD= Personal Flotation Device
  PGM= Precision Guided Munitions
  Pickle= To fire or drop one weapon when the release button is depressed
  PMS= Preventive Maintenance Service
  Pnl= Panel
  POL= Petroleum, Oil, Lubricant
  Powered AGE= Generators, air conditioners, compressors, hydraulic test stands, etc.
  PPH= Pounds Per Hour
  PPM= Pounds Per Minute
  PPI= Planned Point of Impact
  Primary AB Eyelids= Interior adjustable exhaust nozzles, located inside the AB section
  PSI= Pounds per Square Inch
  PSOB= Pilots System Operators Bucket (Lower part of the ejection seat)
  PTSP= Pressure/Temperature Sensor Probe (T shaped probe found inside of aircraft intakes)
Q.  Quebec
  QA= Quality Assurance (After 1978)
  QC= Quality Control (Prior to 1978)
  QD= Quick Disconnect
  QRC= Quick Replacement Component
  QRF= Quick Reaction Force
  QRK= Quick Replacement Kit
  QRM= Quick Replacement Module
R.  Romeo
  R2= Remove and Replace
  R3= Remove, Repair, Reinstall
  RADAR= Radio Aerial Detection And Ranging
  RAF= Royal Air Force
  RAL= Right Aft Launcher
  RAM= Radar Absorbent Material
  RAM Team= Rapid Area Maintenance Team
  RAT= Ram Air Turbine
  RATO= Rocket Assist Take Off
  RCP= Rear Cockpit
  RCP= Right Center Pylon
  RCS= Radar Cross Section
  RDF= Radio Direction Finder
  Red Ball= Request for priority maintenance assistance
  Red Flag= US Air Force sponsored aircrew air combat training program
  RESCAP= Aircraft performing CAP for Rescue operations.
  RF= Radio Frequency
  RFL= Right Fwd Launcher
  RHAW= Radar Homing And Warning
  RIO= Radar Intercept Officer (USN) Also see WSO
  RIP= Right Inbd Pylon
  Rip & Strip= Parts are taken from one or more aircraft to fill fly away kits prior to a deployment
  Ripple= Weapons release steps from station to station or pylon to pylon to maintain balance
  RMG= Right Main Gear
  RMGD= Right Main Gear Door
  RNG= Range
  ROE= Rules Of Engagement
  RON= Remain Over Night
  ROP= Right Obd Pylon
  ROPE= Radome Open, Package Extended
  RPV= Remote Piloted Vehicle
  Rt= Right
  R/T= Receiver, Transmitter
  RWR= Radar Warning Receiver
S.  Sierra
  SAI= Standby Attitude Indicator
  Salvo= Weapons will release or fire as long as release button is held down
  SAM= Surface to Air Missile
  SAR= Search And Rescue
  Scan= Radar is looking or searching a specific area or location
  SEADS= Suppress Enemy Air Defense System
  Secondary AB Eyelids= Exterior adjustable engine exhaust nozzles
  Sel= Select
  Short Between Headset= Aircrew doesn't know what he is talking about.  Results in a lot of CND's
  SLAM= Stand-off Land Attack Missile
  Slicks= Term used to describe the MK-80 series of low drag bombs
  SLR= Side Looking Radar
  SLUFF= Short Little Ugly Fat Fellow (A-7)
  Smart Bomb= Any guided conventional bomb
  SNAFU= Situation Normal, All Fowled Up
  SOBAC= Signed Off By Air Crew
  SOF= Supervisor Of Flying
  Soft Target= Non armored vehicles
  Soft Wing= Aircraft equipped with leading edge wing slats
  Sortie= One flight or mission flown by an aircraft
  SOV= Shut Off Valve
  Special Weapon= A nuclear bomb
  Speed of Heat= Traveling at max allowable speed
  SPR= Single Point Refueling.  An adapter is hooked to the aircraft allowing high pressure refueling.  Normal flow is around 600 GPM
  Squawk= Send or Transmit
  Stab= Stabilizer
  Stand Off= Safe area when attacking a target
  Store(s) = Any external ordinance
  STOL= Short Take Off and Landing
  SWA= Special Weapons Adapter
  SWP= Special Weapons Panel
T.  Tango
  T1= Number one turbine section (Engine)
  T2= Number two turbine section (Engine)
  TACAN= Tactical Air Navigation
  TAD= Temporary Assigned Duty (USN & Marines)
  TAIM= Training Air Intercept Missile (Fully functional missile with an inert warhead)
  TARPS= Tactical Airborne Reconnaissance Pod
  TAS= True Air Speed
  TBA= To Be Announced
  TBO= Time Between Overhaul
  TDA= Temporary Duty Assignment (USN & Marines)
  TDY= Temporary Duty (USAF)
  TEF= Trailing Edge Flaps
  TER= Triple Ejector Rack.  Bomb suspension adapter allowing up to three bombs or other ordinance to be loaded
  TFR= Terrain Following Radar
  TIC= Target Intercept Computer
  TIG= Time In Grade
  TIS= Time In Service
  TISEO= Target Identification System, Electro Optical
  TIT= Turbine Inlet Temperature
  TK= Tank (Fuel)
  TLP= Tactical Leadership Program (German sponsored program teaching tactical leadership)
  Top Gun= US Navy sponsored aircrew air combat training program
  TP= Target Practice (Ammo)
  TPT= Tail Pipe Temperature
  TR= Tail rotor
  Track= Radar is following one target (See Paint)
  T/R Pac= Transformer/Rectifier Package
  TTSP= Total Temperature Sensor Probe
  Tune= Missile receiving data from the Radar prior to launch (See NFT)
  Turkey Feathers= Aerodynamic covering that goes over the Secondary AB Eyelids
  TWS= Track While Scan (Radar)
U.  Uniform
  UAV= Unmanned Aerial Vehicle
  UHF= Ultra High Frequency
  Unload= Maneuver where aircraft enters a negative G condition and at the same time engines put into Max AB. The result is rapid acceleration of the aircraft.
  USAF= United States Air Force
  USAFE= United States Air Force in Europe
V.  Victor
  Vert= Vertical
  VFR= Visual Flight Rules
  VHF= Very High Frequency
  Victor Alert= Aircraft on alert status loaded with Nukes
  VOR= VHF Omni-directional Radio
  VTOL= Vertical Take Off and Landing
  VVI= Vertical Velocity Indicator
W.  Whiskey
  WCP= Weapons Control Panel
  Whiskey Alert= Aircraft on alert status loaded for Air to Ground mission
  Willy Pete= White Phosphorus
  Wing King= Wing Commander
  WOD= Wind Over Deck
  Wpn= Weapon
  WRM= War Ready Material (Also War Reserve Material)
  WSEM= Weapons System Evaluation Missile (Non launchable missile that contains a recorder to verify aircraft launch system).  (Pronounced Wizzum)
  WSEP= Weapons System Evaluation Program (Pronounced Wessup)
  WSO= Weapons System Operator (Pronounced wizzo) (USAF)
  WSP= Weapons Select Panel
  WW= Wild Weasel. (Any aircraft used to kill radar sites)
X.  X Ray
  X-Mitter= Transmitter
  X-Mit= Transmit
  X-Ponder= Transponder
  X-Ray Alert= Aircraft on Recon Alert Status
Y.  Yankee
  Yankee Alert= Aircraft on alert status loaded for RESCAP
Z.  Zulu
  Zulu= GM time
  Zulu Alert= Aircraft on Air Defense Alert
Up dated 4 April 2011
Berny
 Phormer Phantom Phixer
On the bench
    October 2006
Posted by Mist086 on Thursday, February 15, 2007 4:15 PM
Have a couple of Navy Terms.  Don't know if they'd be needed but what the hay
RIO- Radar Intercept Officer (Like the WSO in the Air Force)
TARPS-Tactical Airborne Reconnaisance Pod
    June 2006
Posted by SoD Stitch on Thursday, February 15, 2007 6:00 PM
You forgot GIB = Guy In Back
1/48th Monogram A-37 Dragonfly: 95% (so close!); 1/35th Academy UH-60L: 90%; 1/35th Dragon "Ersatz" M10: 75%; 1/35th DML E-100 Super Heavy Tank: 100%; 1/48 YF-12A, 95%; 1/48 U-2R: 90%; 1/48 B-58 Hustler: 50%; 1/32 F-117, 50%; 1/48 Rafale M: 50%; 1/48 F-105D: 75%; 1/48 SOS A-1H Skyraider: 50%; 1/48th Hobby Boss Su-27: 50%; 1/16th Revell Lamborghini Countach: 75%; 1/12th Otaki Lamborghini Countach: 25%; Tamiya 1/35th M3 Bradley Cavalry Fighting Vehicle: 25%
Posted by berny13 on Thursday, February 15, 2007 6:54 PM
TARPS and GIB added.  RIO was already listed.  Thanks for your input.
Berny
On the bench
    August 2005
Posted by Phil_H on Friday, February 16, 2007 7:00 AM
A few more:
ACES = Advanced Crew Escape System (Ejection Seat)
ARM = Anti-Radiation Missile
AWG = Airborne Weapons Group
BarCAP = Barrier Combat Air Patrol
CAG = Commander, Air Group
CAG Bird = CAG's personal aircraft
CSAR - combat search and rescue
CFT = Conformal Fuel Tank
ELINT = Electronic Intelligence
FAC = Forward Air Controller
IRST = Infrared Search/Track
JDAM = Joint Direct Attack Weapon
JSOW = Joint Stand-Off Weapon
JTIDS = Joint Tactical Information Distribution System
LANTIRN = low-altitude navigation and targeting infrared for night
RAM = Radar Absorbent Material
RCS = radar cross-section
SLAM = Stand-Off Land Attack Missile
TFR = Terrain Following Radar
Posted by berny13 on Saturday, February 17, 2007 9:05 AM
 Phil_H wrote:
A few more:
List up dated.  Thanks.
Berny
On the bench
    May 2003
Posted by DrewH on Saturday, February 17, 2007 11:37 AM
Here's a couple we used in the Canadian military:
A/C - aircraft
U/S - un-servicable  means the thing don't work
SOP - Standard Operating Procedures
Take this plastic and model it!
Posted by Anonymous on Monday, February 19, 2007 10:07 PM
Here's a couple of slight corrections.
RADAR, RAdio Detection And Ranging
RADAR is an odd one, it uses two letters of the first word, then the singles.
VOR, VHF Omni Range  (or VHF Omnidirectional Range).
I never understood why 'range' was in there.  the distance was provided with TACAN, civilian has VOR with DME. --edit--  nevermind on this.  I found a reference that called it VHFOmni Radio Range
I'm pretty sure
INS is Inertial Nav System
and a new one
FLR Forward Looking RADAR (used on the RF-4C)
Posted by berny13 on Wednesday, February 21, 2007 8:46 AM
I'm pretty sure
and a new one
FLR and SLR added.
 I checked my Pilots Flight manual put out by the FAA (1990) and Student Reference Guide (1977) put out by Embry Riddle.   The FAA guide only tells how VOR works but the Embry Riddle guide gives a defination as VHF Omni-Directional Radio.  So which one is correct?
As for RADAR, Balantine Books, 1960, Allied Secret Weapons Of WW ll, states the British first used the term RADAR.  Their early system would only detect airborne targets so they named it Radio Aerial Detection And Ranging.  The US was also working on a system, after the British started research.  The US system was called "Detection by radio waves".  The US Navy also started research on a system years later.  None of the other knew research was being done.
The US and Hughes was working one system and the Navy and Westinghouse was working another.  The US system used a higher frequency and was able to detect airborne targets at a longer range.  The British used a lower sprectrum frequency and had a much cleaner return.  The Navy and Westinghouse used a mid spectrum frequency and a pulse signal which allowed them to pick up surface returns.   After all three started working together the US system, which required a larger antenna and more power, was adapted using the Westinghouse pulse signal.  The result was a very long range system that also could detect surface targets.
The British system was used for aircraft radar systems, using the pulse system.  It did not require a large antenna or heavy generators to power the system.
You are correct on INS.  I left the L off the end.  I must have had my head up and locked. Big Smile [:D]
Berny
On the bench
    January 2003
Posted by Triarius on Wednesday, February 21, 2007 8:21 PM
You also left out:
TIRFU: This Is Really Fouled Up
FUBAR: Fouled Up Beyond All Recognition
    December 2004
Posted by Hippy-Ed on Wednesday, February 21, 2007 9:42 PM
alrighty Berny!!Tongue [:P] I got this bookmarked now!!Approve [^]
If you lose your sense of humor, you've lost everything
Posted by berny13 on Wednesday, March 7, 2007 8:17 PM
I have added the following to the list.
AB
AFB
AVTR
FOL
JP
LOX
MCAS
MIL
NAS
O2
Pickle
POL
Ripple
Salvo
Berny
On the bench
Posted by berny13 on Tuesday, March 13, 2007 8:35 AM
The following up dates have been added
Depot
IRAN
Lock On
Paint
PDM
SAI
Scan
Track
TWS
Berny
On the bench
    August 2004
Posted by Thehannaman2 on Wednesday, June 6, 2007 12:38 PM
Very cool resource.  Thanks for the effort Berny!
Justen
"The distance between genius and insanity is measured only by success."
Member IPMS Niagara Frontier. "The BuffCon Boys."
IPMSUSA Member 45680
    November 2006
Posted by ollie on Wednesday, July 4, 2007 4:20 PM
Some more that i did not notice:
CRP - Contra rotating propellor
CO - Commanding officer
Pitiot Tube - Measures the airspeed of ai aircraft
Airscrew - The Propellor
Pusher Propellor -
Tractor Propellor -
Reverse thrust -
Interuptor gear - Stops a machine gun from firing when the prop is in front of it
www.overthefencephotography.co.uk - aircraft photos.
    October 2004
Posted by TMN1 on Monday, July 23, 2007 1:52 PM
Here are a couple more:
ISA = Integrated Servo Actuator (the civilian version would be PCU = Power Control Unit)
TIT = Turbine Inlet Temperature
N1 RPM = Low pressure Turbine/Compressor RPM
N2 RPM = High pressure Turbine/compressor RPM
This one you already have CAS, but it can also be something else.
CAS = Calculated Air Speed
Posted by berny13 on Monday, July 23, 2007 6:43 PM
Pusher Propellor -
Tractor Propellor -
Reverse thrust -
I will add CRP and CO to the list.  The other items a self explanatory.
Berny
On the bench
Posted by berny13 on Monday, July 23, 2007 7:04 PM
Thanks for the items.  Just one question though.  You listed N1 RPM and N2 RPM.  Where did you find or hear about these terms.  For the engines I am famaliar with, (J-33. J-47, J-57, J-75, J-79 and TF-33) the compressor section was named N1 (Low pressure side) and N2 (High pressure side).  The J-33 had a single stage compressor and RPM was taken from that single stage.  RPM was taken from the N2 section on all of the others. The Turbine section T1 (First stage turbine) and T2 (Second stage turbine) did not have a RPM reading or temperature reading.  The temp was taken in the tail pipe (TPT or EGT).
Berny
On the bench
    October 2004
Posted by TMN1 on Monday, July 23, 2007 11:52 PM
Where i heard it is easy. Im an aircraft mechanic and heard about in my training. But you are right on most, if not all, of the twin spool engines the RPM read out in the cockpit is only the N2 RPM. But during engine tests you can also get a N1 RPM read out either in the cockpit or on some test equipment.
    May 2003
Posted by qmiester on Sunday, August 5, 2007 8:51 AM
Berny
You list Fox as fire missile.  I was always under the impression that when the pilot broadcast Fox 1, 2 or 3, he was announcing that he had just fired a missile with the number indicating type of missile - am I wrong in that?
Quincy
Posted by berny13 on Friday, August 10, 2007 10:16 AM
 qmiester wrote:
Berny
That is correct.  During combat a pilot will call out Fox 2 to let other crews know a Sidewinder has been launched and to stay out of the way.  You don't want to get between the shooter and target and have the missile go after you.  The same with Fox 1, a Sparrow launch.  Don't fly between the target and shooter and cause the radar to break lock, or worse yet have it track after you.  When I said Fox, I didn't include the 1,2,&,3.
Berny
On the bench
Posted by BlackWolf3945 on Sunday, August 12, 2007 4:16 AM
To further clarify the significance of 'Fox' radio calls...
The number refers not to the missile's model type, (AIM-7 Sparrow, AIM-9 Sidewinder, etc) but to the method of guidance used by the missile that has been fired.
'Fox 1' refers to the firing of any semi-active radar-guided missile.
'Fox 2' refers to the firing of any infrared-guided missile.
'Fox 3' refers to the firing of any active radar-guided missile.
Fade to Black...
Posted by berny13 on Tuesday, August 21, 2007 7:39 PM
Fade to Black...
That is correct Steve.  In my post I used Sidewinder and Sparrow in the generic term.  Crews also called out "Guns, Guns, Guns", when firing their guns in air to air combat.
Berny
On the bench
    October 2007
Posted by btp2k2 on Friday, October 19, 2007 12:52 PM
How could we forget "Sierra Hotel"?
Paul I Like Tomcats!
    October 2007
Posted by Milairjunkie on Friday, October 19, 2007 2:20 PM
BINGO - point of safe return (fuel),
LAPES Low Altitude Parachute Extraction System (see C-130)
Posted by berny13 on Saturday, October 20, 2007 8:04 AM
List up dated.  Thanks for your input.
Berny
On the bench
Posted by berny13 on Saturday, October 20, 2007 8:08 AM
I know what it stands for, but can you give me a definition that would be acceptable to print?
Berny
On the bench
    January 2003
Posted by Triarius on Saturday, October 20, 2007 10:43 AM
Very warm fecal matter.
Posted by berny13 on Saturday, October 20, 2007 2:12 PM
If I added that, I would have to add Kilo Mike Alpha.  Confused [%-)]
Berny
On the bench
    January 2003
Posted by Triarius on Saturday, October 20, 2007 2:31 PM
Okay, how about "100°C protocoprolites" for Sierra Hotel. You can claim educational credit for making people look it up.
For Kilo Mike Alpha, try "osculate dorsal terminus."
Mischief [:-,]
