Supplier of model wheels or casters
    January 2010
Posted by rob44 on Thursday, May 6, 2021 7:57 PM
I am building the Atomic City 1:12 Mercury Space Capsule. I want to display it on a scratch bult support cradle. Does anyone know where I might purchase some scale model wheels or casters for the support cradle?
Thanks!
    May 2009
Posted by Pawel on Friday, May 7, 2021 5:10 PM
Hello!
Mostly out of curiosity - how big would those wheels have to be and how many of them?
How about drawing them up in 3D and then 3D printing them?
Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
Posted by keavdog on Friday, May 7, 2021 5:46 PM
Thanks,
John
    January 2010
Posted by rob44 on Saturday, May 8, 2021 6:54 AM
Thank you both for your reply. I need 4 of them about 1/3-1/4 of an inch. The Castors you suggested may work!
Posted by Don Stauffer on Saturday, May 8, 2021 9:27 AM
I have made wheels that size by sawing off short lengths from plastic rod.  Usually castors do not have much detail.  I make the swivel mounts from brass rod- twenty or thirty mil.
Broken or lost a number of tailwheels and done that several times.
    January 2010
Posted by rob44 on Saturday, May 8, 2021 4:37 PM
Thank you! Great idea! I will do that.
    August 2005
Posted by EdGrune on Wednesday, May 12, 2021 7:53 PM
Agree with the above regarding slicing plastic rod. But what if your rod is not the right duameter
Another approach may be laminating discs of sheet plastic.  Use a paper hole punch (office supply or craft store item) to punch holes in sheet styrene. 1/4 inch is a common size.  Harbor Freight Tools offers a die punch set with sizes 1/8 to 3/4 inches (it is also my go to for punching out round tape masks).  Glue multiple layers together for appropriate thickness.   Sand the tread even
Evergreen is a common brand, but also look at the plastic yard sale signs at hardware stores (not corrugated).   My local big box hardware store sells plastic sign blanks that are about 30 thousands.  They come in an attractive yellow, lime green, or shocking pink.  But you are going to paint anyway.
The sheet stock also allows you to fabricate the U shaped axle brackets that support the wheels and attach to the frame
Posted by Don Stauffer on Thursday, May 13, 2021 8:26 AM
EdGrune
Since he is looking for wheels less than a quarter inch, I believe you will find more sizes of plastic rod than punches.  I think plastruct rod goes up in 1/32 increments.
    October 2019
Posted by Tanker-Builder on Sunday, May 16, 2021 8:47 AM
Ah;
    But Don! Evergreen goes up in thousandths! You start with .010 rod all the way up to 1/8 inch rod. Plastruct is okay. But even in my engineering office, it WAS NOT our go to building material. The material Plastruct used wasn't Styrene (it was ABS) and it wasn't carried by every store you would think would carry it! They do carry a full line of Styrene now though. But I think it is in thousandths too.
