Lufbery wrote: |
However, I've not seen any photos that show the heavily accented panel lines that are current in vogue. |
I just stumbled upon this thread, and felt I had to "set you straight". :-)
Here is a link to such a photo of a Royal Danish Air Force F-100F which is probably dating from mid-to-late seventies. In 1968 (coinciding with the introduction of the Draken, I think), RDAF introduced overall olive green camouflage as a replacement for green/gray NATO and NMF finishes used until that point.
I am unsure of the exact shade of that green, probably somewhere between 34102 and 34079. The point is though, that it probably wasn't too standardized to begin with, and further more, and relevant to the topic of this thread, it faded tremendously. I have a picture book from 1980 (when the F-100 was in the process of being replaced with F-16) showing airframes with all kinds of shades, some being as light as a khaki sand color, some (on a Draken) being a bluish (!) gray. (That, however, might just be another case of bad color reproduction, although I wouldn't be surprised if it wasn't.)
As you will note from the linked picture, the panel's edges are generally much darker than their centers. This is probably due to patchup painting - dragging a paint brush along the panel line? - not because they fade that way. However, the engine section, as is normal for the F-100, is faded in the typical pattern, which incidentally also seems to follow panel lines. I suppose, the panel edges, being supported by ribs, can dissipate the heat differently than the middle of the panels, thereby locally reducing the fading.
I was going to say that perhaps John Vojtech should build a green, Danish F-100 next time, but then I saw the links to his own pictures. From these, it becomes obvious that the cover page of the 01/07 FSM issue leaves a lot to be desired when it comes to photographic reproduction. Looking at the pictures in the article confirms this. I don't want to blame anyone, but clearly something must have gone wrong. Someone much have clicked the wrong buttons in Photoshop for sure. Perhaps sharpening has resulted in an erroneous enhanced contrast, which badly affects the subtle shading.
I hope FSM will figure out how to avoid this the next time. Faithful reproduction is essential whether we want to look at pictures of reference objects, or the models that are made from them.
I still think Vojtech's C-130 was fairly criticized for being overweathered, though.
-Lasse
