Aircraft Trivia Quiz
    July 2004
Posted by stikpusher on Monday, November 1, 2010 8:38 PM
How about F-84F? It went from Thunderjet to Thunderstreak, but was essentially an all new aircraft.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by osher on Monday, November 1, 2010 9:00 PM
It's not the one I was thinking of, but, it does answer the question!  It was supposed to be the F-96A, but instead was produced as the F-84F.  The aircraft I had in mind was the Bristol Bisley, which entered production as the Bristol Blenheim Mk.V.
Over to you!
    April 2009
Posted by gmat on Wednesday, November 3, 2010 5:34 PM
Not much movement. Is it a post-war English aircraft?
Posted by osher on Wednesday, November 3, 2010 5:38 PM
Stikpusher won it, we're waiting for his question.
    August 2009
Posted by Sparrowhyperion on Wednesday, November 3, 2010 6:23 PM
 Don't forget the US Martin B57 Marauder.  Which I thinkl was based on the A variant which still had the shorter wings.
Scorpiomikey
Ill take a stab and say the Canberra? Been through more incarnations than i can count on 2 hands and still gets called the Canberra. Even the NASA one with the big turbofans on it.
In the Hangar: 1/48 Hobby Boss F/A-18D RAAF Hornet,
On the Tarmac:  F4U-1D RNZAF Corsair 1/48 Scale.
    April 2009
Posted by gmat on Thursday, November 4, 2010 4:14 AM
Sorry,
Marauder was the name for the Martin B-26. Canberra, used by English Electric,  was the official US name for the B-57, although Martin or the USAF apparently also tried to use the name Night Intruder for the B-57.
Best wishes,
Grant
    August 2009
Posted by Sparrowhyperion on Thursday, November 4, 2010 11:11 AM
You're right.  I must not have had enough coffee when I posted that.  I should have said Intruder, which is for some reason what Revell called the US Martin version of the Canberra.  It get's kind of confusing with the USN A-6 series, but this is pretty old.(1970), I actually have that kit.  probably going to sell it though.  I can't do that small of detail anymore.  It's Kit H-132 from their old Strategic Air Power series.  I's not the best kit around of the Canberra.  It's pretty basic with a one piece pilot/instruments piece.  I need to find a few pieces that went missing before I can do anything with it.
gmat
Sorry,
Best wishes,
Grant
    October 2007
Posted by Milairjunkie on Friday, November 12, 2010 6:54 AM
Stikpusher?
Posted by osher on Friday, November 12, 2010 6:58 AM
Actually, it's been over a week, so, I'll jump in:
Which sub-sonic airliner has the record for the fastest Atlantic crossing?
    August 2010
Posted by Scottkow on Friday, November 12, 2010 7:29 AM
Boeing 747
Posted by osher on Friday, November 12, 2010 7:37 AM
Nope.  The answer might surprise you, especially in terms of age
    September 2009
Posted by B17Pilot on Friday, November 12, 2010 8:17 AM
Boeing 707
Posted by osher on Friday, November 12, 2010 8:23 AM
It was 4 engined, but it wasn't a Boeing...  The engine configuration was unusual, for this type of aircraft
Posted by osher on Friday, November 12, 2010 8:38 AM
OK, here are some clues, so, let's see if it can be solved:
Designed to operate in locations where it's greatest competitor couldn't - only for that condition to be changed, leaving it at a disadvantage.
Originally had one fewer engine
Ostensibly lower economics due to fuel, but, high availability countered this
Famous for it's military roles, especially one, where it's probably the best in this specialist class
Almost became a bomber!  Also, a double-decker version was seriously proposed.
Came in two distinct types
It might have had engines from an export version America's top fighter of the period
Noted for being quiet inside, and partially for the same reason, it became a very good aircraft for this specialist role.
    August 2010
Posted by Scottkow on Friday, November 12, 2010 8:39 AM
Convair 990
    April 2009
Posted by gmat on Friday, November 12, 2010 2:27 PM
I think that it's British.
Grant
Posted by osher on Friday, November 12, 2010 2:43 PM
It is indeed British!  Quite a remarkable aircraft, but which one?
    August 2009
Posted by Sparrowhyperion on Friday, November 12, 2010 2:58 PM
I dunno.  Maybe the Dehavilland Comet?  I know that now the fastest subsonic Prop plane is the 747, and the fastest subsonic civilian jet is the Citation X.
    August 2009
Posted by Sparrowhyperion on Friday, November 12, 2010 2:59 PM
Made Big Typo, I meant to say fastest prop is the B29, 747 was fastest 4 engine airliner subsonic.
Posted by osher on Friday, November 12, 2010 3:01 PM
Nope!  Slightly later.  This aircraft holds the record for a trans-Atlantic passenger airliner, as well as everything else I mentioned.  More?  OK, American pilots chose it for something, because it's so good at this, better than American aircraft (for a specific reason), and it shares this interesting engine configuration with a Russian jetliner.
Posted by osher on Friday, November 12, 2010 3:08 PM
OK, more clues:
As well as the double deck version, twin and triple fuselage versions were also proposed.  However, the only new version that made it into service was the extended version.  The aircraft remains in service, and will do for another 5 years.
    October 2007
Posted by Milairjunkie on Friday, November 12, 2010 4:33 PM
This beastie;
Posted by osher on Friday, November 12, 2010 4:44 PM
That's it, the VC-10!  The 4 Conway engines gave it incredible power, but this is partially because it was designed to operate from short runways that were 'hot and high', where the Boeing 707 couldn't operate, as it was short on power.  This was a need of BOAC, which had many lines to the Empire in Asia and Africa, where these airports existed.  The 'problem' was that most of these locations extended their runways, meaning that the the Boeing 707, and others, could now be used, and a high-powered jet airliner was now an expensive luxury.
However, what was bad for the civilian market was good for the military.  The VC-10 became probably the world's best tanker, in part because the engine arrangement reduced turbulence from jet blast.  Apparently, American pilots prefer to tanker behind it, even over nearer American tankers...
    April 2009
Posted by gmat on Saturday, November 13, 2010 12:41 AM
I was thinking of the Comet, but that was wrong.
Good question.
Best wishes,
Grant
    October 2007
Posted by Milairjunkie on Saturday, November 13, 2010 6:26 AM
Cheers!
The largest fixed wing aircraft ever operated by the US Navy was?
    April 2004
Posted by rudedog72 on Saturday, November 13, 2010 7:24 AM
I believe the answer to this was the Lockheed R6v Constitution.  They entered service right after WW II and remained until about 1950.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former."
- Albert Einstein (1879-1955)
    October 2007
Posted by Milairjunkie on Saturday, November 13, 2010 9:43 AM
Yes rudedog72, the Constitution woul be correct - over to you;
    April 2004
Posted by rudedog72 on Saturday, November 13, 2010 2:05 PM
I would have posted the picture to go with, but I was having problems.
Ok, how about this one, its kinda easy I admti.
How did the west get its first close up look at the MIG-15?
    January 2009
Posted by fermis on Saturday, November 13, 2010 2:24 PM
Defected Korean???
    April 2009
Posted by gmat on Saturday, November 13, 2010 2:29 PM
Skin divers are part of the answer?
