Aircraft Trivia Quiz
    March 2010
Posted by Scorpiomikey on Sunday, March 3, 2013 2:04 PM
I feel like i should know it, but i just cant figure it out.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    February 2011
Posted by PhilB on Sunday, March 3, 2013 3:08 PM
This type held its air force's unrefuelled endurance record - almost four normal working days!
    October 2007
Posted by Milairjunkie on Sunday, March 3, 2013 3:38 PM
I was looking at recce aircraft, but didn't consider Maritime - the Argus?
    February 2011
Posted by PhilB on Sunday, March 3, 2013 5:50 PM
Yes, the Canadair Argus.  Taking a licence to build variants of the Britannia, Canadair got rid of the pressurised fuselage and the turboprop engines which seemed a retrograde step but the unpressurised fuselage allowed a bomb bay with access in flight and the substitution of Wright R-3350 turbo compound engines, whilst a step back in technology,  decreased fuel burn and thus extended the range/endurance.  Though turbo compound engines did give trouble Canadair's walking away from Bristol engines saved them a heap more.
The ASW/search radar which was the prime component in the aircraft's effectiveness was first obtained from the USA but in the second variant came from the UK.
They kept away from Bristol turbo props when they revisited the airframe and keeping the Britannia fuselage, stretched it, remodelled the cockpit and, adding RR Tyne engines, presented the RCAF with the Yukon which was further developed for the civil market as the CL-44 and Cl-44D4.
    October 2007
Posted by Milairjunkie on Monday, March 4, 2013 4:09 AM
This now virtually retired aircraft was very task specific but wasn't used in anger in it's intended role, it was however used in anger in a rather different theatre than was planned.
It shares an engine with one other currently active type & can start under it's own steam.
    February 2011
Posted by PhilB on Monday, March 4, 2013 6:12 AM
The first bit of the clue fits the AVRO Vulcan but I can't work out how the second bit fits in.
    October 2007
Posted by Milairjunkie on Monday, March 4, 2013 6:24 AM
PhilB
This aircraft isn't quite as retired as XH558, there are still 4 operating & they arn't retiring quite as imminently. Like many aircraft the last few example have ended carrying out test work.
One example of this type did achieve it's five minutes of fame.
    March 2004
Posted by subfixer on Monday, March 4, 2013 6:38 AM
I am going to take a wild guess and say the B-57 Canberra.
I'm from the government and I'm here to help.
    October 2007
Posted by Milairjunkie on Monday, March 4, 2013 8:57 AM
Not the B-57.
This aircraft's single design role was more specific than the B-57.
Only one other production military aircraft has used the engine fitted to this aircraft & the engine helped give this aircraft a name.
The fame was prime time International.
    January 2009
Posted by F-8fanatic on Monday, March 4, 2013 10:34 AM
Sounds like the S-3 Viking to me.....shares the engine with the A-10 Warthog.  Originally designed and put into service as an ASW platform, but ended up being used in a limited offensive strike role in both Desert Storm and OIF, taking out targets like Silkworm missile sites with Maverick missiles.  It had its time inthe spotlight as Navy One when President Bush landed on the USS Abraham Lincoln in the co-pilot's seat of one. Retired from front-line service in 2009, but NASA got 4 of them, and 3 more went to Navy test squadron VX-30.  At least four of them still fly today from what I have seen.
    October 2007
Posted by Milairjunkie on Monday, March 4, 2013 10:42 AM
F-8fanatic
Spot on, the S-3 with it's GE TF34's Yes
    January 2009
Posted by F-8fanatic on Monday, March 4, 2013 12:32 PM
Alright, this was a prototype design.  Only one ever flew, and on its one and only flight, it was forced to make an emergency landing.  This aircraft combined two uncommon design features also used on the P-39 Airacobra with an uncommon design feature of the Heinkel He-177.  A second prototype was under construction but was destroyed by a bombing attack.  On its only flight, the prototype suffered from the same problem that the Focke Wulf FW-190 did.
    March 2010
Posted by Scorpiomikey on Monday, March 4, 2013 5:11 PM
Piaggio P.119?
My signature
    March 2009
Posted by wolfhammer1 on Monday, March 4, 2013 10:20 PM
Heinkel 119?
    January 2009
Posted by F-8fanatic on Monday, March 4, 2013 11:02 PM
Not the Piaggio, good guess though.  The P.119 actually flew quite well, apart from excessive vibration when all guns were being fired.  The plane I am looking for has three basic differences from the Piaggio--
1--it shared two characteristics with the Airacobra, while the P.119 has only one.
2--there was only one P.119 ever built, whereas the one I am looking for actually had two examples built.  The second one was in finishing stages of construction when it was destroyed.
3--the P.119 flew more than once, and did not suffer the same gremlin that the FW 190 did.
    January 2009
Posted by F-8fanatic on Monday, March 4, 2013 11:07 PM
Not the Heinkel either, there were 8 of those built, and some of them were flown in different test roles.
Also, of the two guesses so far, the Heinkel is the only one that hits on the second characteristic of sharing a feature with the Heinkel 177 bomber.
I will also say this--the aircraft I am looking for was definitely built for a military role but it was not to be a fighter.
    October 2007
Posted by Milairjunkie on Tuesday, March 5, 2013 3:49 AM
The Yokosuka R2Y(1)?
It had a mid mounted engine driving through a shaft & tricycle landing gear like the P-39 & used a compound / coupled engine like the He-177.
The 190 prototype suffered from heat issues & although I can't find anything definate on it I imagine that the R2Y like many coupled / compound engined aircraft had heat issues.
    January 2009
Posted by F-8fanatic on Wednesday, March 6, 2013 12:04 AM
yes, it is the R2Y1, and yes it did have overheating issues.  That is what caused its one and only flight to end early--overheating.
    October 2007
Posted by Milairjunkie on Wednesday, March 6, 2013 2:58 AM
I don't know why, but it just smelled like a Japanese aircraft...
This aircraft which was built in the hundreds was the result of a committee request & it's design paved the way for a commonly used engine configuration which has now gone out of fashion with this type of aircraft. This aircraft also had unusual transparencies?
    February 2011
Posted by PhilB on Wednesday, March 6, 2013 3:36 AM
SE-210 Caravelle
    October 2007
Posted by Milairjunkie on Wednesday, March 6, 2013 5:59 AM
I should have known better than to post anything commercial.....
Yes, the Caravelle with it's rear engine configuration & unusually shaped windows;
    February 2011
Posted by PhilB on Wednesday, March 6, 2013 7:03 AM
Not all commercial types are easy - as we might see!!
This type was first revealed as a model at an airshow on a different continent from the manufacturer's home base.   Three years elapsed before a start was made on the prototype which eventually flew after a further three years.  A year later it was the star of the show at an airshow in its home country but less than 12 months later the project was abandoned with just one aircraft built..
A watered down version of the type is currently under consideration by new backers.
    August 2009
Posted by Sparrowhyperion on Wednesday, March 6, 2013 10:37 AM
TU-144 Concordski?
In the Hangar: 1/48 Hobby Boss F/A-18D RAAF Hornet,
On the Tarmac:  F4U-1D RNZAF Corsair 1/48 Scale.
    February 2011
Posted by PhilB on Wednesday, March 6, 2013 12:09 PM
No, as far as I know there is no movement to build a new version of the TU-144 though this type, whilst far slower than supersonic, at the time was the fastest in its class.
    October 2007
Posted by Milairjunkie on Wednesday, March 6, 2013 7:29 PM
Su-80?
    February 2011
Posted by PhilB on Thursday, March 7, 2013 1:30 AM
There has been more than one SU80.  This type is a contemporary but somewhat bigger.
    January 2003
Posted by davros on Thursday, March 7, 2013 5:17 AM
Could it be the Antonov An-225 Mriya?
    February 2011
Posted by PhilB on Thursday, March 7, 2013 6:43 AM
Now that is getting far too large.  This type was rather ambitious in some ways for its manufacturer and what would have been a major advanced feature was abandoned when the latest plans for a relaunch were announced.
One reason given for the planned relaunch is the ageing of a type whose manufacturer ceased business in the year after this type's prototype's first flight, the new backers seeing a ruggedness in their design not available in the current competition.
    October 2007
Posted by Milairjunkie on Thursday, March 7, 2013 12:48 PM
The IPTN N-250?
    February 2011
Posted by PhilB on Thursday, March 7, 2013 1:32 PM
Now just where did you drag that out of?Geeked  Over to you.
