NEW Helo UPDATE PICS!
Posted by Anonymous on Sunday, January 25, 2004 12:05 AM
I still say that I want to rent those little guys who are working on Troy's projects! The workmanship as usual is superb.
Posted by Papa-Echo-64 on Sunday, January 25, 2004 1:34 AM
I could never do that!....they are my specail friends! Tongue [:P]
Though that would be cool!.....like the Carburator fairy!.....you just put the old carb or injectors under your pillow at night and wahla! ( or your Wifes pillow )
Thanks for the kind words!
This kit even has the exposed elbow juntion trans unit at the bottom of the rear stabilizer! ...It needed some help so I added some aluminum rods to clean up the shafts....could not help myself, I also had to thin the plastic in that area a bit ...otherwise the tail booms sheet metal would be 5 inches thick if not more in scale!
Straighten up and fly right.....
    November 2003
Posted by chopperfan on Sunday, January 25, 2004 10:14 AM
QUOTE: Originally posted by Papa-Echo-64
Tonight I robbed my Revell 1/32 Euro Copter ambulance chopper for the very detailed two part medical stretcher to stick inside along with a rolled up blanket from a 1/35 scale German truck...painted it silver, like a thermal blanket and a Fire extinguisher.
Troy.
Last night at work I had a thought on the thermal blanket.
Go to your friendly "Mom 'n Pop" burger joint, not one of the chains. They use a sheet of paper to wrap their burgers in that has foil on one side and paper on the other.
Cut a piece to the proper dimensions and fold it up. It seems that that would be a little more to scale. Thumbs Up [tup] Big Smile [:D]
Just a thought that I thought I'd pass along.
Randie Cowboy [C):-)]
Randie [C):-)]Agape Models Without them? The men on the ground would have to work a lot harder. You can help. Please keep 'em flying! http://www.airtanker.com/
Posted by Papa-Echo-64 on Sunday, January 25, 2004 12:19 PM
Thanks Randie!
Sounds like a very cool idea!....but the blanket is already painted and glued into place....I put it back by the rear ramp......its 1/35 scale....the same as my Helo.
    July 2003
Posted by oldhooker on Sunday, January 25, 2004 5:33 PM
Woooah Troy...
Looking GREAT... those seat backs look good, man!! Smile [:)]
Frank
