AH-64A "Devils Dance" C Company, 1/229th Attack Helicopter Battalion
    June 2006
Posted by Bulldog 09 on Wednesday, August 22, 2012 8:44 PM
Finished this build up a couple of days ago. This particular build has taken a little over three years to build. It is comprised of parts from four 1/72 kits (2 Academy, 1 Hasegawa, and 1 HobbyBoss), after market sets from CMK & Eduards, and a total of 1200+ scratch built pieces. None of this would have been possible without the outstanding custom decals from a friend of mine Joseph Osborn, or the invaluable technical advice and reference material from Jon Bernstein, Tony Morgan, and the US Army. So I'll shut up now and post the photos. Please let me know if you all have any suggestions or corrections.
Devil Dance
AH-64A 89-0202
C Company, 1/229th Attack Helicopter Battalion aka."Blue Max"
Dave Fassett
    June 2006
Double post.
    June 2006
Posted by Bulldog 09 on Wednesday, August 22, 2012 8:48 PM
Dave Fassett
    July 2004
Posted by stikpusher on Wednesday, August 22, 2012 9:29 PM
 Wow!!!!! Lots of how did you do that questions... so I will start with one. How did you do the "disco ball" countermeasure device?
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    February 2008
Posted by mike_espo on Wednesday, August 22, 2012 10:22 PM
That is one fantastic build!!! Bow Down
Makes me think that 1/72 scale is worthwhile.Big Smile
On the workbench:
Trumpeter 148 MiG -21F
    June 2006
Posted by Bulldog 09 on Thursday, August 23, 2012 9:41 AM
Thank you all so much for the outstanding feedback.
Thanks for the question Stikpusher.
I made the "Disco Ball" by sanding the Eduards PE piece until all of the silver coating was removed and the brass was revealed completely.  Next I polished the brass with a piece of fine sandpaper to give it a high shine look, and sprayed a coat of Model Master Acrylic Clear Red over it. I Let this dry for a day or so. I then cut a piece of clear Mylar film, which was purchased at Hobby Lobby, to fit over the PE piece. Make this a little bigger than the piece to be covered, this will allow you to handle it better. I brushed a coat of future over the PE piece and lay the Mylar over it while it is still wet. Gently press this down and let it set for a while.
After this was dry I used a new #11 blade and scored the recesses between each of the lenses on the disco ball. After this was done I brushed another coat of future over it,and let this dry. Finally I trimmed all excess Mylar, folded the piece to shape, and covered it one more time with future. You may have a lense pop off here or there, if this happens just cut a piece of Mylar to the correct size and reattach it with future.
I hope this answers your question and please feel free to ask more.
Thanks again,
Dave Fassett
    March 2010
Posted by Hercmech on Thursday, August 23, 2012 10:46 AM
Absolutley stunning build...not one thing to nitpick on it. Hats off to you.
13151015
    January 2010
Posted by CrashTestDummy on Thursday, August 23, 2012 4:14 PM
Superlatives abound on this example you've done!  Awesome work.  I did a 1/48th scale example, starting with that really bad Revell kit and adding a TON of extra details to it, and didn't produce ANYTHING close to what you've done here.  Very, very nice craftsmanship!
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
    June 2006
Posted by Bulldog 09 on Thursday, August 23, 2012 8:37 PM
Thank you very much Hercmech and Gene for the outstanding feedback.
Dave Fassett
    September 2006
Posted by Blitzwing on Friday, August 24, 2012 4:31 AM
Wow that is 1/72 scale. Absolutely stunning build.
URL=http://picasion.com/]
    July 2010
Posted by Echo139er on Friday, August 24, 2012 7:58 AM
Incredibly awesome detail for a 1/72 scale.  very nice!
Posted by Melgyver on Saturday, August 25, 2012 7:58 PM
Absolutely amazing!  Great detail work!  Looks like the real thing!  My hat is off to you!
Clear Left!
Mel
    August 2011
Posted by Centerdeck2 on Sunday, August 26, 2012 8:10 AM
Great job mel!  My question is about the non-skid.
Shepherd Book once said to me, "If you can't do something smart, do something right."
    December 2011
Posted by TroyH on Sunday, August 26, 2012 5:56 PM
EXQUISITE! Want to eventually do the same to my 1:48. Will be happy if it comes out half as nice. Just can't find the tail rotor shaft bay detail and a couple of the smaller compartments in my scale.
    June 2006
Posted by Bulldog 09 on Monday, August 27, 2012 7:50 AM
Thank you all for the excellent feedback and comments, it means a lot.
Centerdeck2,
The non-skid was done with Mr. Surfacer 500. First what I do is mask off the area to be treated. Second use a stiff short bristle brush and "dab" the Mr. Surfacer onto the area. Work the area a little until you have the texture you are looking for, (A small note here, work a little section at a time, Mr. Surfacer does not take long to set up).  While it is still somewhat wet you can rescribe your panel lines by just running a sawing needle down the existing panel line.  Finally paint the area once it is dry and your done. The nice thing about using Mr. Surfacer for this is that if you don't like it ,or you mess up, you can just sand it off without a problem. Give it a try, it's pretty easy and the results are pretty convincing.
Dave Fassett
    October 2007
Posted by Milairjunkie on Monday, August 27, 2012 9:15 AM
Wow, that's a build & a half!
Like has been said, the disco ball & anti-slip are excellently done, the open panels are something else as well, in particular the tail rotor shaft.
I can't put my finger on exactly what does it, but it has something very realistic going on (to my eyes anyway).
Bow Down
    June 2006
Posted by Bulldog 09 on Tuesday, August 28, 2012 8:39 AM
Thank you very Milairjunkie.
The tail rotor was for me the most challenging. The challenge was to represent the actual assembly and its major parts, but not to over do it and make it to busy. The next challenge I faced was getting everything to fit and scaled properly. In the end it took three weeks and 56 scratch built pieces to get it just right, but I feel it was worth it.
Dave Fassett
Posted by Ish47guy on Thursday, September 6, 2012 1:38 PM
Holy crap, Dave!  Nice, man!  Now I'm friggen angry that I wont be there to see it person at SuperCon.
    June 2006
Posted by Bulldog 09 on Tuesday, September 11, 2012 8:38 AM
Thank you Ish. Man it sucks you couldn't make it this year, oh well there is always next year.
    November 2012
Posted by mmerc20 on Sunday, November 11, 2012 1:26 PM
That's amazing Dave! I had to sign up for an account just to post and tell you that. I was a Blue Max member and 202 was there with me when I was serving. It "belonged" to a very good friend. When we deployed to Bosnia we had custom head cushion covers made and I found this picture taken 12 years ago of 202. I thought you would like to see it. I don't know if I have any other pictures, but drop me a line sometime if you want.
SGT Mike
    March 2004
Posted by subfixer on Monday, November 12, 2012 8:52 AM
Bad-Azz!
I'm from the government and I'm here to help.
Posted by Gamera on Monday, November 12, 2012 9:01 AM
Wow, how did I miss this- awesome work there!!!
    June 2006
Posted by Bulldog 09 on Sunday, November 18, 2012 6:47 PM
Mike, Thank you so much Sir, your compliment means a lot. It is always good to hear feedback from a member of a unit I portray in a build. I have a couple of more "Blue Max" builds scheduled  in 1/48, so any pictures you have would be outstanding. You can never have enough reference material, I will drop you a line ASAP. Again thank you Sir for your outstanding feedback and offer.
Dave Fassett
    June 2006
Posted by Bulldog 09 on Sunday, November 18, 2012 6:52 PM
Subfixer and Gamera , Thank you so much gentlemen for the outstanding feedback on my build.
Dave Fassett
    February 2007
Posted by Buckeye on Wednesday, November 21, 2012 11:36 AM
That would be amazing work in 1/48 let alone 1/72!!
    June 2012
Posted by ghostt180 on Thursday, November 22, 2012 2:19 AM
Wow. I normally build german armour and do WW2 german dio's so don't scan this forum page. I just happened to randomly look through this forum page for something different and this AH-64 absolutely blew me away! That is one piece of work to be proud of. Stunning. I am speechless.
    August 2009
Posted by TREYZX10R on Saturday, November 24, 2012 6:26 PM
Amazing detail and at that scale all the more so!
    June 2006
Posted by Bulldog 09 on Sunday, November 25, 2012 10:48 AM
Gentlemen, thank you all for the outstanding comments. It is the feedback from fellow modelers, like yourselves, that have made this build worthwhile. Thanks again.
Dave Fassett
    January 2014
Posted by Silver on Thursday, November 19, 2015 4:07 PM
I know it has been a while back.But;I seeN your project and it inspired me in building the 1/32 nd scale version like yours.I had to scratch build engines and everything else.They look identicle.Thanks.
    January 2014
Posted by Silver on Sunday, April 3, 2016 7:27 PM
I just came up your old post, and I love your Apache.I just completed one In 1/32 nd  scale .w/ the same detail w/ scratch build parts and a second opened up scratch build engine w/a little help from the academy 1/35 scale UH-60 engines .i will try to post it in the FSM reader Gallery .Its hard to do that because they do not like super detail projects To show up.My email is benzay@comcast.net  Take care and happy modeling
