Ok I have applied some White Mulliput . i need to make this brass looking color dome . I guess this would be some kind on inlet air intake .Maybe someone will let me knowEnjoyRick
I been working slowly on this engine build . I hope the end results come out good .
Enjoy
Rick
I started the fireplace today . Little cold outside here in Indiana
Lucy and Nigel
Nigel
Added hydraulic tube .
I have little more engine update . Also Nigel and Lucy got his hair cut today .. He's my little man .. Lucy my little angel , but could not get her photo . She would not sit long enough
Little more update on the engine build .I hope to finish it this weekend . Next problem for me ,is how to paint it .EnjoyRick
Not much modeling going on .I decided to upgrade the model work bench .
I really like this setup .
I built the top out of Maple wood .i been working on this for about month . I went to Ikea yesterday pick up a drawer system and legs
Before
Nigel checking out the new work bench
Another photo .Still need organized
Its so much stronger than a card table
good job of model building. Your new bench is Outstanding. It should make the models go together much faster and without any mistakes, well almost
Steve
Building the perfect model---just not quite yet
infofrog Ok I have applied some White Mulliput . i need to make this brass looking color dome . I guess this would be some kind on inlet air intake .Maybe someone will let me knowEnjoyRick
Rick,
I think you are referring to the large orange-ish part which is the inlet. If it's anything like the H-60, up close it looks like paper mache gauze with a cross-hatched type of pattern in it. The color is like a brownish orange with a tan-type color in some areas. I would just mix a couple drops of brown with some orange and base coat it, then drybrush a light tan or sand color to almost a tamiya desert yellow type of shade. Something along those lines. If the texture from your milliput is rough, that's ok, as the exterior is like pretty rough on the real thing. That said, I'm going off what I know and I don't have experience with 53's, but they are both made by Sikorsky.
Everything to this point looks awesome, I am definitely going to save this thread for when I get around to the one I have in the stash!
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
Thank you . Yes something so simple is hard to get that color correct .At least for me
Another thing though is that the color can vary across the body too, so if you don't really have a uniform color, it doesn't matter. Some areas can be pretty brownm some pretty tan, and some pretty orange. And the two engines don't have to match either. So you're safe with whatever happens!
Thank you Little update on my engine build . I have The paint finished . I really like it . Came out very nice .My only issue is the orange brown color ( i could not get that color ) . I know its not correct , but good enough for me .EnjoyRick
Looks close enough for me. Kudos!
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Thanks all I Toned the engine color a bit . I call it finished engine .i started the exterior photo etch .EnjoyRick
No modeling at this moment.
But my air compressor I built locked up . I used the wrong compressor for this type of app .
So I made a video about my second and better air compressor set .This set up is very nice ,,
Enjoy my video
https://youtu.be/3HOkZVbtkZY?list=PLy7i6CQkHypTP4nOK9N6QgZrA5HWtOzeQ
I not sure , But when this forum changed .I have hard time with adding links. Sometimes they work , more often not
I'm just blown away by what you've done so far. You got some mad skills my friend. I'll pay more attention to this now that I've noticed it. Can't believe I let this epic build slip past me.
BK
On the bench:
Tamiya 1/35 M4A3E8 "Fury" with crew,
1/32 Kittyhawk Kingfisher,
1/35 Meng Panther Ausf A Early,
1/48 Pro Modeller P-51C "Boise Bee"
2022 Completed:
1/25 Revell 29 Highboy
1/48 Tamiya Sea Harrier
1/25 Revell 70 Boss 429 Mustang
1/48 Hasegawa D3A1 Type 99 Val
BrandonK I'm just blown away by what you've done so far. You got some mad skills my friend. I'll pay more attention to this now that I've noticed it. Can't believe I let this epic build slip past me. BK
Thank you. I'm just a slow worker . With life and work . You know what I mean
Being slow means little more added to the build
Not much been going on , only my day job here lately . i just want to update some photo's . I have a the front nose attached . Was not a great fit , but it works . I also have extra photo etch installed
Looks good. Big bird. Motivates me to work on my 46.
midnightprowler Looks good. Big bird. Motivates me to work on my 46.
Yes it a little big . I would never bought this model , but for a 2014 christmas gift from the family . I really enjoy this kit . I'm sure glad to have it . .
I built a rear antenna and a dome . Not sure what the dome is for .
I installed a side guide wire or ground wire . Not sure what this is
I just want share my snowy blizzard day
We may get 12 inches of snow or more today
The work youve done on this kit is just absolutely amazing!
No bucks, no Buck Rogers
I been working ion the rear section . The fold hinge / hydraulic
Ha!!! Nice! Scratchbuilding a model of one would be interesting...
Cheers, LeeTree Remember, Safety Fast!!!
Thank you
I been working on the underside . Landing gear . I add some Hydraulic hoses and photo Etch
Installed the lift system above the side rear door
rick
Nice. What will you use for masking?
So much detail. I don't even know where to start. It is looking really awesome.
